Gparted worked fine in Ubuntu 14.04 and 14.10 (I'm not sure about 15.04)) but I'm having trouble installing it in 15.10 from the software center. It gives the error: “Package dependencies cannot be resolved.” I tried the following answer suggested in the forum posting “Gparted not working”:
Try removing these packages gparted libatkmm-1.6-1v5 libgtkmm-2.4-1v5 libgtkmm-3.0-1v5 pavucontrol type in this command.
sudo apt-get remove gparted libatkmm-1.6-1v5 libgtkmm-2.4-1v5 libgtkmm-3.0-1v5 pavucontrol
and then install ubuntu-desktop if it removes it.
sudo apt-get install ubuntu-desktop gparted libatkmm-1.6-1v5 libgtkmm-2.4-1v5 libgtkmm-3.0-1v5 pavucontrol
But when I did this, I got the following error in the terminal:
gparted : libatkmm-1.6-1 (>= 2.22.1) but it is not installable
libglibmm-2.4-1c2a (>= 2.42.0) but it is not installable
libgtkmm-2.4-1c2a (>= 1:2.24.0) but it is not installable
libpangomm-1.4-1 (>= 2.27.1) but it is not installable
libsigc++-2.0-0c2a (>= 2.2.0) but it is not installable
Is there a way to find out what is missing and broken?
John
  • 35
You could try using apt-get instead of the software center
sudo apt-get install gparted
if it still complains about unmet dependencies apt-get can try to fix them with:
sudo apt-get install -f
L_W
  • 166
