-1
I was trying to install Wine. It used to work, but I get this message:
  wine1.7 : Depends: wine1.7-i386 (= 1:1.7.55-0ubuntu1)
How do I get rid of broken packages?
muru
  • 207,228
You can run a check using apt, from the man page;
check
       check is a diagnostic tool; it updates the package cache and checks
       for broken dependencies.
Simply run;
$ sudo apt-get check
You can also try to run your apt-get command with the '-f' option (again from the man page);
-f, --fix-broken
       Fix; attempt to correct a system with broken dependencies in place.
       This option, when used with install/remove, can omit any packages
       to permit APT to deduce a likely solution. If packages are
       specified, these have to completely correct the problem. The option
       is sometimes necessary when running APT for the first time; APT
       itself does not allow broken package dependencies to exist on a
       system. It is possible that a system's dependency structure can be
       so corrupt as to require manual intervention (which usually means
       using dpkg --remove to eliminate some of the offending packages).
       Use of this option together with -m may produce an error in some
       situations. Configuration Item: APT::Get::Fix-Broken.
Your command would simply be;
$ sudo apt-get -f install win1.7
dirk
  • 1,802
