I currently have three drives:
  1. 120 GB SSD with ubuntu 14.04
  2. 2TB WD with windows 10
  3. 1TB hitachi with pictures and files.
What I would like to do is dual boot between Windows 10 and Ubunutu - with the GRUB window. The thing is when all three drives are connected to the tower, nothing boots. I call see all HDD in BIOS. Separately, the ssd goes right into Ubuntu - disconnect that, connect the 2TB and that goes into windows - showing that everything works fine. I can't figure it out. Any help would be appreciated.
Computer Specs:
Antec Sonata III Case with 500W Power Supply
ASUS P7P55D-E Pro ATX Intel Motherboard
EVGA GeForce 9500 GT 01G-P3-N959-TR Video Card
Intel Core i7-860 2.8GHz LGA 1156 95W Quad-Core Processor
G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory x 2 (for a total of 8GB)
andrew.46
  • 39,359
Do you know on which hard drive your /boot partition is ? It must be your primary boot devices set in BIOS.
Then under Ubuntu try to do
sudo update-grub
It will detect all your bootable devices and create the grub menu that will allow you to choose your OS during boot.
Kgaut
  • 126
