nohup should work for you, what was your exact command? Maybe you're missing something. Here's section from wikipedia about it:
Nohupping backgrounded jobs is typically used to avoid terminating them when logging
off from a remote SSH session. A different issue that often arises in this situation
is that ssh is refusing to log off ("hangs"), since it refuses to lose any data
from/to the background job(s). This problem can also be overcome by redirecting all
three I/O streams:
nohup ./myprogram > foo.out 2> foo.err < /dev/null &
So you could do something like:
ssh -n -f user@remotebox "sh -c 'cd /foo/bar; nohup ./myprogram > foo.out 2> foo.err < /dev/null &'"
Or if that still doesn't work, you can try screen. It will allow you to run your process in the "background", and it will keep running after you logout.
First, ssh over to the remote box, then from there use screen and start your process, and you can give your screen a session name if you want. You won't really notice anything different, but start your process in that session. You can than exit out of the screen session by using the command Ctrl-a d. It will look something like this:
user@remotebox:~$ screen -S foobarsession
user@remotebox:~$ startmyprocess
[detached from 4865.foobarsession]
user@remotebox:~$
You can then exit out of your ssh session, and the process will keep running. To reconnect to the screen session later on, ssh back to the remote box and use screen -r to reconnect. You can use screen -ls to list the sessions.
user@remotebox:~$ screen -ls
There is a screen on:
4865.foobarsession (10/05/2012 11:10:57 AM) (Detached)
1 Socket in /var/run/screen/S-user
user@remotebox:~$ screen -r foobarsession
4865.foobarsession (10/05/2012 11:10:57 AM) (Attached)
user@remotebox:~$
