How do I remove exactly same stuff I have installed or system have installed with adding support for a language for example? Is there a procedure I can follow? Apt-get remove, autoremove or purge is not what I am looking for, it leaves stuff behind.
I am currently looking into debfoster, but I hope that I am overseeing something easier and more native.
In this moment I have to restore my system from a snapshot to get it into previous setup, I am working on international application, when I install and uninstall for example Chinese, I will end up with several unwanted fonts that were not there before and it makes my testing pointless.
Update:
To update and clarify my question, I already know that package installations are logged a month ago I asked How to properly remove Chinese support and I found a solution, packages installed including fonts I want to delete are only in /var/log/dpkg.log. I am looking for automation or some tool, that will automate this so I do not have to process logs every time I install and uninstall new language or an application. Apparently Ubuntu has a tiny flaw and it does not uninstall fonts on language removal, I do install a new language and then delete it several times a day for testing, I have a script I made today where I put everything from logs that does not uninstall and I still hope I am reinventing a wheel and there is already some procedure in place that keeps track of what files and other stuff package is touching and making sure it will be deleted on removal.
