During the install I have to hit [ENTER] in order for the install to proceed on the command:
apt-get install openjdk-7-jre
Is there a way to avoid this prompt?
Old question but still not answered and relevant. You need to install the headless package instead. At the time of this writing version 11 is out so I am using that as example:
apt install -y openjdk-11-jre-headless
or for JDK
apt install -y openjdk-11-jdk-headless
Easy way to do this
apt update
apt upgrade
java -version
willie
  • 109
You can add the -y option i.e. apt-get -y install openjdk-7-jre
from the apt-get manual:
-y, --yes, --assume-yes Automatic yes to prompts; assume "yes" as answer to all prompts and run non-interactively. If an undesirable situation, such as changing a held package, trying to install a unauthenticated package or removing an essential package occurs then apt-get will abort. Configuration Item: APT::Get::Assume-Yes.
Edit: To accept the java license, the solution is here:
Installing Java Automatically (With Silent Option)
mosin
