If your showmount -e shows you the correct shares, you may have mapped UID/GID incorrectly.
From this how to page:
Note regarding UID/GID permissions on NFSv4 without Kerberos
To make UID/GUD work as with NFSv3, set sec=sys both in the server's /etc/export and in the client's /etc/fstab. This will make
NFSv4 work with the old host-based security scheme.
They do not work. Can someone please help investigating? Following this guide will result in UID/GID on the export being
generic despite having same UID on client and server. (According to my
experience it works at least with "precise", if uid/gid are equal on
both sides. hwehner) Mounting same share on NFSv3 works correctly with
regards to UID/GID. Does this need Kerberos to work fully? According
to http://arstechnica.com/civis/viewtopic.php?f=16&t=1128994 and
http://opensolaris.org/jive/thread.jspa?threadID=68381 you need to use
Kerberos for the mapping to have any effect.
This is a possibly related bug: http://bugs.debian.org/cgi-bin/bugreport.cgi?bug=500778
Not clear what is meant by UID/GID on the export being generic. This
guide does not explicitly state that idmapd must also run on the
client side, i.e. /etc/default/nfs-common needs the same settings as
described in the server section. If idmapd is running the UID/GID are
mapped correctly. Check with ps ax|grep rpc that rpc.idmapd is
running.
I know that it's not clear but it's the only possible answer that I can give (as I'm also seeking the answer).
EDIT: As stated here, Kerberos isn't needed.
