I want to install ANT from downloaded zip: apache-ant-1.9.6-bin.zip. How to do it ?
Asked
Active
Viewed 6,604 times
That is the Windows file you downloaded. You need the .tar.gz and that download has a file named INSTALL with a link to the installation manual:
For installation instructions see the manual in the docs subdirectory or online at http://ant.apache.org/manual/index.html.
It is a binairy download so all you need to to do un-tar it to a location (I would advice something like /opt/apache-ant-1.9.6/ with a symlink to /opt/apache-ant/ so you can install several verions).
You need JDK (1.7+ adviced) and set a few things:
- Add the
bindirectory to your path - Set the
ANT_HOMEenvironment variable to the directory where you installed Ant. - Optionally, set the
JAVA_HOMEenvironment variable
Example:
Assume Ant is installed in
/opt/apache-ant/. The following sets up the environment:export ANT_HOME=/opt/apache-ant/ export JAVA_HOME=/opt/apache-ant/jdk1.7.0_51 export PATH=${PATH}:${ANT_HOME}/bin
The link to the manual also has instructions on checking if all went well.
Rinzwind
- 309,379
