I have a bunch of .mp4 files (DRM free). Each file comprises two episodes of a kids TV show. I would like to simply split the file in two without re-encoding. What's the best way to do this? Preferably with a GUI (as I need to skip to the correct part of each file to find the divider between the two episodes).
Thanks,
I recommend opening the video in a media player to find the time where you want to split it. Then you can use ffmpeg with the following script. It does not re-encode the video.
#!/bin/bash
Split Video Script
Usage: script_name file_name split-point
Example: split_video_script bugs_bunny.mp4 31:23
Instructions:
1. Type the name of your script (if it is already added to ~/bin and marked as executable).
2. Type the file name including path to it if necessary.
3. Type the time where you want to split the video. It goes in minutes:seconds
Get length in seconds
length=$(echo "$2" | awk -F: '{print ($1 * 60) + $2}')
Get filename without extension
fname="${1%.*}"
First half
ffmpeg -i "${fname}.mp4" -c copy -t "$length" "${fname}1.mp4"
Second half
ffmpeg -i "${fname}.mp4" -c copy -ss "$length" "${fname}2.mp4"
Update: I recently needed to update this script because of an issue with the second half. So, now I have to process the second half of it. You would add in the parameters that are specific to your original video. You can use mediainfo, ffprobe or ffmpeg -i to find the needed information about your original video.
#!/bin/bash
if [ -z "$1" ]; then echo "Usage: $0 file-name" exit 1 fi
read -p "Enter time to split video (hh:mm:ss.mmm) " split_time
ext="${1##.}" fname="${1%.}"
First half
ffmpeg -i "$1" -c copy -t "$split_time" -c:s copy "${fname}1.${ext}"
Second half
ffmpeg -ss "$split_time" -i "$1" -c:v libx264 -crf 17 -preset veryfast -r 30 -s 1920x1080 -c:a aac -ac 2 -b:a 256k -ar 44100 -pix_fmt yuv420p -movflags faststart -c:s copy "${fname}2.${ext}"
jbrock
  • 3,417
I needed to use your script to split a video into thirds instead of splitting the mp4 into two. Here is my version of the script:
#!/bin/bash
NUM_OF_SPLITS=3
main() { # Requires: $ brew install ffmpeg
# total length in seconds
total_length=$(ffprobe -v quiet -of csv=p=0 -show_entries format=duration "$1")
# Get filename without extension
fname="${1%.*}"
split_time=$(echo "$total_length"/"$NUM_OF_SPLITS" | bc -l)
declare -a start_times
declare -a end_times
for((i=0; i < $num_of_splits; i++)); do
    local output_file="${fname}_"part$i".mp4"
    if [[ "$i" -eq 0 ]]; then
        local start_time=0
        local end_time="$split_time"
        ffmpeg -i "${fname}.mp4" -c copy -t "$end_time" "$output_file"
    else
        local start_time="${end_times[$i-1]}"
        local end_time=$(echo "$start_time "*" 2" | bc -l)
        # echo "Start time: $start_time"
        # echo "End time: $end_time"
        ffmpeg -ss "$start_time" -to "$end_time"  -i "${fname}.mp4" -c copy "$output_file"
    fi
    start_times+=($start_time)
    end_times+=("$end_time")
done
Split Video Script
Instructions:
main "$1"
