Background
I've successfully installed Ubuntu 64bit 14.04.03 Desktop on my old White Core 2 Duo iMac
  • Linux is a second OS, with OS X 10.7.5 still in place and usable.
  • The only install recipe I found to work was amd64+mac option from an external CD drive - internal is broken, USB didn't work
  • "Try Ubuntu" from Live CD works fine
  • refind 0.10.2
  • I selected install grub to the specific partition during installation
Problem
Refind boot menu with a Linux boot option shown. However selecting it causes a black screen for 10 seconds approx and then rapid flashing white cursor in top left hand corner, caps lock unresponsive, CTRL-alt-Delete has no effect
Things I've tried
  • using live CD to adjust default grub linux params to include nomodeset noapic acpi=off
  • complete power off instead of reboot
  • searching google for many hours
  • holding down option key during boot - only existing OS X + recovery are shown
  • putting the nomodeset noapic acpi=off options in the refind boot parameters via the F2 editor
Conclusions
  • My older iMac will only boot Linux in Legacy aka BIOS mode. This is how the live CD works, I checked /sys/firmware/efi and its not present
  • I don't believe Refind is even trying to do a legacy boot, it is using a EFI boot
  • There is this thing called hybrid MBR which the author of Refind hates with a passion, however this might be the only way forward
Questions
  • Is it possible to force legacy BIOS boot from refind?
  • Do I even need grub? Does Refind bypass this and boot the kernel itself?
  • will I have to resort to this hybrid MBR thing?
  • Is it possible to put refind into some kind of debug mode so I can see exactly what is happening, whether Ubuntu is even starting?
  • Should I even need Refind - is it possible to get partition to show up in Boot+Hold option key startup?
Adam
  • 291
AFAIK, Macs will not boot in BIOS/CSM/legacy mode from legal GPT disks; they require an MBR or hybrid MBR to boot in BIOS mode. rEFInd, though, doesn't check for this detail; it tries to start a BIOS-mode boot when asked to do so, even if the disk uses GPT. From your description, I suspect that this is what's happening. Thus, if you've got a BIOS-mode installation on a GPT disk, it won't work; you must create a hybrid MBR. Note that rEFInd will only attempt an EFI-mode boot if it detects an EFI-mode boot loader, which it sounds like you have not installed. Thus, rEFInd is almost certainly not attempting an EFI-mode boot of Ubuntu.
BTW, I'm the author of GPT fdisk and maintainer of rEFInd. Hybrid MBRs are dangerous things -- I've answered far too many questions from people who've wiped out their disks because of hybrid MBRs. Unfortunately, Apple designed its firmware to use them as a "key" to unlock BIOS-mode booting, so you're pretty much stuck with them if that's what you need.
Backing up a bit, most Macs will boot Linux in EFI mode just fine. Given your description, though, you may have a 32-bit EFI. You can check this in rEFInd by reading the About/Info page; it should identify your firmware as being 32-bit or 64-bit (check the Platform: line). If you have a 32-bit EFI, you must use a 32-bit boot loader to boot Linux in EFI mode. This is difficult to do for various reasons -- the installers for 32-bit versions of Ubuntu can't be booted in EFI mode, and the installers for 64-bit versions of Ubuntu come with nothing but the 64-bit EFI boot loader. There are ways around this, but they involve significant hoop-jumping. See this question for more on this subject.
Rod Smith
  • 45,120
  • 66
  • 108
