I tried to install haskell-platform and I am getting the following unmet dependencies.
Reading package lists...
Building dependency tree...
Reading state information...
The following packages have unmet dependencies: haskell-platform : Depends: ghc (>= 7.6.3) but it is not going to be installed Depends: ghc (< 7.6.3+) but it is not going to be installed Depends: libghc-async-dev (>= 2.0.1.4) but it is not going to be installed Depends: libghc-async-dev (< 2.0.1.4+) but it is not going to be installed Depends: libghc-attoparsec-dev (>= 0.10.4.0) but it is not going to be installed Depends: libghc-attoparsec-dev (< 0.10.4.0+) but it is not going to be installed Depends: libghc-case-insensitive-dev (>= 1.0.0.1) but it is not going to be installed Depends: libghc-case-insensitive-dev (< 1.1.0.2+) but it is not going to be installed Depends: libghc-cgi-dev (>= 3001.1.8.3) but it is not going to be installed Depends: libghc-cgi-dev (< 3001.1.8.3+) but it is not going to be installed Depends: libghc-fgl-dev (>= 5.4.2.4) but it is not going to be installed Depends: libghc-fgl-dev (< 5.4.2.4+) but it is not going to be installed Depends: libghc-gluraw-dev (>= 1.3.0.0) but it is not going to be installed Depends: libghc-gluraw-dev (< 1.3.0.0+) but it is not going to be installed Depends: libghc-glut-dev (>= 2.4.0.0) but it is not going to be installed Depends: libghc-glut-dev (< 2.4.0.0+) but it is not going to be installed Depends: libghc-hashable-dev (>= 1.2.1.0) but it is not going to be installed Depends: libghc-hashable-dev (< 1.2.1.0+) but it is not going to be installed Depends: libghc-haskell-src-dev (>= 1.0.1.5) but it is not going to be installed Depends: libghc-haskell-src-dev (< 1.0.1.5+) but it is not going to be installed Depends: libghc-html-dev (>= 1.0.1.2) but it is not going to be installed Depends: libghc-html-dev (< 1.0.1.2+) but it is not going to be installed Depends: libghc-http-dev (>= 1:4000.2.8) but it is not going to be installed Depends: libghc-http-dev (< 1:4000.2.8+) but it is not going to be installed Depends: libghc-hunit-dev (>= 1.2.5.2) but it is not going to be installed Depends: libghc-hunit-dev (< 1.2.5.2+) but it is not going to be installed Depends: libghc-mtl-dev (>= 2.1.2) but it is not going to be installed Depends: libghc-mtl-dev (< 2.1.2+) but it is not going to be installed Depends: libghc-network-dev (>= 2.4.1.2) but it is not going to be installed Depends: libghc-network-dev (< 2.4.1.2+) but it is not going to be installed Depends: libghc-opengl-dev (>= 2.8.0.0) but it is not going to be installed Depends: libghc-opengl-dev (< 2.8.0.0+) but it is not going to be installed Depends: libghc-parallel-dev (>= 3.2.0.3) but it is not going to be installed Depends: libghc-parallel-dev (< 3.2.0.3+) but it is not going to be installed Depends: libghc-parsec3-dev (>= 3.1.3) but it is not going to be installed Depends: libghc-parsec3-dev (< 3.1.3+) but it is not going to be installed Depends: libghc-primitive-dev (>= 0.5.0.1) but it is not going to be installed Depends: libghc-primitive-dev (< 0.5.0.1+) but it is not going to be installed Depends: libghc-quickcheck2-dev (>= 2.6) but it is not going to be installed Depends: libghc-quickcheck2-dev (< 2.6+) but it is not going to be installed Depends: libghc-regex-base-dev (>= 0.93.2) but it is not going to be installed Depends: libghc-regex-base-dev (< 0.93.2+) but it is not going to be installed Depends: libghc-regex-compat-dev (>= 0.95.1) but it is not going to be installed Depends: libghc-regex-compat-dev (< 0.95.1+) but it is not going to be installed Depends: libghc-regex-posix-dev (>= 0.95.2) but it is not going to be installed Depends: libghc-regex-posix-dev (< 0.95.2+) but it is not going to be installed Depends: libghc-split-dev (>= 0.2.2) but it is not going to be installed Depends: libghc-split-dev (< 0.2.2+) but it is not going to be installed Depends: libghc-stm-dev (>= 2.4.2) but it is not going to be installed Depends: libghc-stm-dev (< 2.4.2+) but it is not going to be installed Depends: libghc-syb-dev (>= 0.4.0) but it is not going to be installed Depends: libghc-syb-dev (< 0.4.0+) but it is not going to be installed Depends: libghc-text-dev (>= 0.11.3.1) but it is not going to be installed Depends: libghc-text-dev (< 0.11.3.1+) but it is not going to be installed Depends: libghc-transformers-dev (>= 0.3.0.0) but it is not going to be installed Depends: libghc-transformers-dev (< 0.3.0.0+) but it is not going to be installed Depends: libghc-unordered-containers-dev (>= 0.2.3.0) but it is not going to be installed Depends: libghc-unordered-containers-dev (< 0.2.3.0+) but it is not going to be installed Depends: libghc-vector-dev (>= 0.10.0.1) but it is not going to be installed Depends: libghc-vector-dev (< 0.10.0.1+) but it is not going to be installed Depends: libghc-xhtml-dev (>= 3000.2.1) but it is not going to be installed Depends: libghc-xhtml-dev (< 3000.2.1+) but it is not going to be installed Depends: libghc-zlib-dev (>= 0.5.4.1) but it is not going to be installed Depends: libghc-zlib-dev (< 0.5.4.1+) but it is not going to be installed Depends: ghc-haddock but it is not going to be installed
These dependencies are different from the other questions, here and here , on this site.
Some packages mentioned in the first question are also the ones I have come across so I implemented the solution there. However I couldn't get it to work (the same dependencies kept coming up).
Leaving it aside for a moment I tried installing the haskell stack. However it requires me to install the package libgmp3-dev. I cannot seem to be able to install it using synaptic or sudo apt-get install.
I am looking for any suggestions to installing haskell-platform or failing that ghc compiler on my system. I am running Ubuntu 14.04.
Please feel free to edit my question or request any information. Thank you in advance for your time.
DBS
  • 201
