I am using haproxy for load balancing mysql.Haproxy is running on Ubuntu 14.04 .I have set ENABLED=1 in /etc/defaults/haproxy file. But when restarted, haproxy doesn't start as daemon. The configuration file looks like this:
global
daemon
defaults
log global
retries 2
timeout connect 3000
timeout server 5000
timeout client 5000
frontend mysql_read
mode tcp
bind *.*.*.*:3308
default_backend cluster_db_read
mode tcp
option tcpka
option mysql-check user haproxy_check
balance roundrobin
server s1 *.*.*.*:3306 check
server s2 *.*.*.*:3306 check backup
listen stats
bind 0.0.0.0:8080
mode http
stats enable
stats uri /
stats realm Strictly\ Private
stats auth user:password
#stats auth Another_User:passwd
The output of sudo netstat -tulpn is as follows
Active Internet connections (only servers)
Proto Recv-Q Send-Q Local Address Foreign Address State PID/Program name
tcp 0 0 127.0.0.1:3306 0.0.0.0:* LISTEN 1078/mysqld
tcp 0 0 192.168.1.102:3308 0.0.0.0:* LISTEN 1834/haproxy
tcp 0 0 0.0.0.0:8080 0.0.0.0:* LISTEN 1834/haproxy
tcp 0 0 127.0.1.1:53 0.0.0.0:* LISTEN 1557/dnsmasq
tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 913/sshd
tcp 0 0 127.0.0.1:631 0.0.0.0:* LISTEN 2145/cupsd
tcp6 0 0 :::22 :::* LISTEN 913/sshd
tcp6 0 0 ::1:631 :::* LISTEN 2145/cupsd
udp 0 0 0.0.0.0:56175 0.0.0.0:* 803/avahi-daemon: r
udp 0 0 0.0.0.0:39839 0.0.0.0:* 1292/dhclient
udp 0 0 127.0.1.1:53 0.0.0.0:* 1557/dnsmasq
udp 0 0 0.0.0.0:68 0.0.0.0:* 1292/dhclient
udp 0 0 0.0.0.0:631 0.0.0.0:* 958/cups-browsed
udp 0 0 0.0.0.0:5353 0.0.0.0:* 803/avahi-daemon: r
udp6 0 0 :::53961 :::* 803/avahi-daemon: r
udp6 0 0 :::5353 :::* 803/avahi-daemon: r
udp6 0 0 :::22178 :::* 1292/dhclient
What changes should be made to make haproxy as a daemon service?
