I have Intellij IDEA 15 (Community) in Downloads folder.
The file name is ideaIC-15.0.3.tar.gz. My operation system is Ubuntu 15.10 for developers. Can anyone help me install it? Thank you.
- 184
Unpack the IntelliJ IDEA distribution archive that you downloaded to where you wish to install the program. We will refer to this destination location as your {installation home} below.
Open a console and cd into "{installation home}/bin" and type:
./idea.sh
to start the application. As a side effect, this will initialize various configuration files in the ~/.IntelliJIdea15 directory.
[OPTIONAL] Add "{installation home}/bin" to your PATH environment variable so that you may start IntelliJ IDEA from any directory.
[OPTIONAL] To adjust the value of the JVM heap size, create ~/.IntelliJIdea15/idea.vmoptions (or idea64.vmoptions if using a 64-bit JDK), and set the -Xms and -Xms paramters. To see how to do this, you can reference the vmoptions file under "{installation home}/bin" as a model.
[OPTIONAL] Changing the location of "config" and "system" directories
By default, IntelliJ IDEA stores all your settings under the ~/.IntelliJIdea15/config directory and uses ~/.IntelliJIdea15/system as a data cache. If you want to change these settings,
Open a console and cd into ~/.IntelliJIdea15/
Create the file "idea.properties" and open it in an editor. Set the idea.system.path and/or idea.config.path variables as desired, for example:
idea.system.path=~/custom/system idea.config.path=~/custom/config
Note that we recommend to store data cache ("system" directory) on a disk with at least 1GB of free space.
Enjoy!
-IntelliJ IDEA Development Team
