New to Ubuntu but highly interested, I have a problem with 14.04 in locating the terminal for command lines? As an alternative to GNOME Terminal, which I assumed would have been installed, I have tried to download GUAKE Terminal but am prevented by a repetitive error message indicating that the download 'requires the installation of untrusted packages' for which I have the options of ('OK' or 'Repair'). Activation of either has no effect on subsequent repeats, always linked to my hitting the installation button.
T.Muir
The terminal for the GNOME environment can be opened one of two ways:
  1. Applications menu -> Accessories -> Terminal.
  2. Keyboard Shortcut: Ctrl+Alt+T
Do either of those get you to a terminal environment?
Parto
  • 15,647
Guake is in the repository. You can install applications from the repository by using apt-get.
Type this at the command line:
$ sudo apt-get install apt-get
If you get an error during the install, please post the exact error.
Most errors associated with installing applications from the repository can be resolved with this command:
$ sudo apt-get update
By the way you can get to the default terminal (gnome-terminal) by hitting Ctrl + Alt+T. Of course you can also get to the default terminal by typing terminal in the search field of Ubuntu Launch button. xterm is also a terminal that you can use for running commandlines.
L. D. James
  • 25,444
