While reading and following this I realized after a while that my front USB ports weren’t detecting anything. The rear ports work fine, however.
lsusb
Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 004 Device 004: ID 148f:5370 Ralink Technology, Corp. RT5370 Wireless Adapter
Bus 004 Device 002: ID 14cd:125c Super Top SD card reader
Bus 004 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 006 Device 002: ID 0a12:0001 Cambridge Silicon Radio, Ltd Bluetooth Dongle (HCI mode)
Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 003: ID 04f2:0833 Chicony Electronics Co., Ltd
Bus 001 Device 004: ID 1c4f:0034 SiGma Micro
dmesg
http://pastebin.com/YJcvJRZK
Yes, I know my drives made by the Ubuntu installer cause errors, but thats not the problem.
Any help is appreciated.
Alan
I had a problem similar to this where my front USB ports wouldn't detect anything except a mouse... It turned out I Needed to turn of USB legacy support in the BIOS. Another thing to look at is that the cable is plugged into the motherboard, its easy to knock a cable loose inside your case. Have these ports ever worked, like with other OS's or is this the first time you've ever tried to use them?
Hope this helps.
