Before, one could configure certain options in Gnome 2.x through the ~/.gtkrc-2.0 file. With Gnome 3, one would assume that ~/.gtkrc-3.0 works but it doesn't.
- 6,406
- 6,111
gtk 3.0 / Gnome 3 settings can be overwritten using ~/.config/gtk-3.0/, with files gtk.css and settings.ini. They do not exist initially so you have to create the directory and files manually. If you create settings.ini add at least a line containing [Settings] in it, otherwise apps will complain about it missing.
See /usr/share/theme/[theme_name]/gtk-3.0/*.css files for hints of what you can change.
Most likely you will want to use gtk.css to override visual settings from the desktop theme with your own preferences. I usually don't edit gtk.css itself but rather append a line saying @import url("gtk-mine.css"); and put my stuff in gtk-mine.css. This way, in case someone ever overwrites that file, I only lose the @import line, not all my personal rules.
Here's a short example of how to override some scrollbar attributes:
~/.config/gtk-3.0/gtk-css:
~/.config/gtk-3.0/gtk-mine.css:
-GtkRange-slider-width: 18;
-GtkScrollbar-has-forward-stepper: 0;
-GtkScrollbar-has-backward-stepper: 0;
-GtkScrollbar-has-secondary-forward-stepper: 0;
-GtkScrollbar-has-secondary-backward-stepper: 0;
-GtkScrollbar-min-slider-length: 30;
.scrollbar.slider.vertical,
.scrollbar.button.vertical {
border-radius: 4;
- 76
- 1
- 2
