I am using Ubuntu 15.10 and encountered some issues with wired connection. after using grub, using Ubuntu recovery option with networking enabled it messed up my wired connection settings.
using:
ifconfig eth0 up
returns:
eth0: ERROR while getting interface flags: No such device
using:
dmesg | grep eth
returns:
[ 2.073397] usbcore: registered new interface driver cdc_ether
[ 2.215551] r8152 2-1:1.0 eth0: v1.08.1 (2015/07/28)
[ 3.237153] r8152 2-1:1.0 enx9cebe8261253: renamed from eth0
[ 69.963790] r8152 2-1:1.0 eth0: v1.08.1 (2015/07/28)
[ 71.017553] r8152 2-1:1.0 enx9cebe8261253: renamed from eth0
[ 195.797143] r8152 2-1:1.0 eth0: v1.08.1 (2015/07/28)
[ 196.861909] r8152 2-1:1.0 enx9cebe8261253: renamed from eth0
[ 229.932958] r8152 2-1:1.0 eth0: v1.08.1 (2015/07/28)
[ 230.981139] r8152 2-1:1.0 enx9cebe8261253: renamed from eth0
Wireless connection still works fine. I'm using laptop (Asus UX305FA), so my wired connection is though usb to ethernet adapter. Wired connection worked out of the box with adapter on fresh install. I would appreciate any help I could get on how to resolve this issue.
Edit:
ip link
returns:
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN mode DEFAULT group default
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
2: wlp2s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP mode DORMANT group default qlen 1000
link/ether 5c:e0:c5:1b:e0:bd brd ff:ff:ff:ff:ff:ff
4: enx9cebe8261253: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP mode DEFAULT group default qlen 1000
link/ether 9c:eb:e8:26:12:53 brd ff:ff:ff:ff:ff:ff
Note that number 3 is missing I think number 3 used to be my original wired connection, but it's no longer recognized when I plug in my ethernet cable.
/etc/udev/rules.d/10-network.rules
There is no such file, do I create a new file with line?
SUBSYSTEM=="net", ACTION=="add", ATTR{address}=="10:c3:7b:4e:1d:6a″,KERNEL=="enp3s0″, NAME="eth0″
Edit2:
ifconfig enx9cebe8261253
returns:
enx9cebe8261253 Link encap:Ethernet  HWaddr 9c:eb:e8:26:12:53
                inet addr:10.250.29.214  Bcast:10.250.29.255  Mask:255.255.255.0
                inet6 addr: fe80::9eeb:e8ff:fe26:1253/64 Scope:Link
                UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
                RX packets:52 errors:0 dropped:0 overruns:0 frame:0
                TX packets:183 errors:0 dropped:0 overruns:0 carrier:0
                collisions:0 txqueuelen:1000
                RX bytes:3866 (3.8 KB)  TX bytes:18573 (18.5 KB)
and wifi
ifconfig wlp2s0
returns:
wlp2s0    Link encap:Ethernet  HWaddr 5c:e0:c5:1b:e0:bd
          inet addr:192.168.43.247  Bcast:192.168.43.255  Mask:255.255.255.0
          inet6 addr: fe80::5ee0:c5ff:fe1b:e0bd/64 Scope:Link
          RX packets:306366 errors:0 dropped:0 overruns:0 frame:0
          TX packets:80425 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:427480060 (427.4 MB)  TX bytes:10062427 (10.0 MB)
Looks pretty much identical, but wireless works and wired does not
Try:
ip link
My output:
alex@IT-CROWD:/etc/udev/rules.d$ ip link
2: enp3s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP mode DEFAULT group default qlen 1000
    link/ether 10:c3:7b:4e:1d:6a brd ff:ff:ff:ff:ff:ff
3: vmnet1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UNKNOWN mode DEFAULT group default qlen 1000
    link/ether 00:50:56:c0:00:01 brd ff:ff:ff:ff:ff:ff
4: vmnet8: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UNKNOWN mode DEFAULT group default qlen 1000
    link/ether 00:50:56:c0:00:08 brd ff:ff:ff:ff:ff:ff
And you can change the device name by defining the name manually with an udev-rule in(if file not existed create):
Add the following line, and don't forget change MAC and KERNEL to your MAC and KERNEL:
These rules will be applied automatically at boot.
Alex13
