Executing wine vcredist_x86.exe
err:winediag:xrandr12_init_modes Broken NVIDIA RandR detected, falling back to RandR 1.0. Please consider using the Nouveau driver instead.
fixme:clusapi:GetNodeClusterState ((null),0x32ebf4) stub!
fixme:advapi:DecryptFileA ("y:\\9f0b7233c6f67752a0a0c705540f3ffd\\", 00000000): stub
fixme:heap:RtlSetHeapInformation (nil) 1 (nil) 0 stub
p11-kit: couldn't load module: /usr/lib/i386-linux-gnu/pkcs11/gnome-keyring-pkcs11.so: /usr/lib/i386-linux-gnu/pkcs11/gnome-keyring-pkcs11.so: cannot open shared object file: No such file or directory
err:winediag:SECUR32_initNTLMSP ntlm_auth was not found or is outdated. Make sure that ntlm_auth >= 3.0.25 is in your path. Usually, you can find it in the winbind package of your distribution.
fixme:advapi:LsaOpenPolicy ((null),0x33f2d8,0x00000001,0x33f2c4) stub
fixme:advapi:LsaClose (0xcafe) stub
fixme:ntdll:NtLockFile I/O completion on lock not implemented yet
Executing w_do_call ie6
Executing load_ie6
This package does not work on a 64-bit installation
Byte Commander
  • 110,243
  1. What Photoshop version is it ?
  2. As says https://www.winehq.org/help : "If you want help with a single application our Application Database is a good place to look." Example: https://appdb.winehq.org/objectManager.php?sClass=application&iId=17
