I'd like to create a new user account and allow them to do maintenance on the server, i.e. install and configure new software, restart the server, manage other users etc...
However, I'd like to disallow access to a specific folder in a home directory.
I understand that for the server maintenance, they'd require sudo access which is fine. But is there a way to disable access to a folder even though they have sudo?
The folder contains sensitive source code of a project, which needs to be protected.
siamii
  • 151
You can encrypt the files/folders using seahorse. It integrates well with Natuilus, and you can simply. Encrypt by clicking right and select encrypt
Reference: https://askubuntu.com/a/27780/488702
I think that the best way is to use EncryptedHome. For sensitive user accounts, create them using the option encrypt-home. Check the caveats on the page if it fits your requirements.
