I've already looked at this question, which helped, but not completely.
Here's the result of lsusb
Bus 003 Device 027: ID 0451:e008 Texas Instruments, Inc. TI-84 Plus Silver Calculator
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            0 (Defined at Interface level)
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0        64
  idVendor           0x0451 Texas Instruments, Inc.
  idProduct          0xe008 TI-84 Plus Silver Calculator
  bcdDevice            1.10
  iManufacturer           1 Texas Instruments Incorporated
  iProduct                2 TI-84 Plus Silver Edition
  iSerial                 0
  bNumConfigurations      1
OTG Descriptor:
  bLength                 3
  bDescriptorType         9
  bmAttributes         0x03
    SRP (Session Request Protocol)
    HNP (Host Negotiation Protocol)
  Configuration Descriptor:
    bLength                 9
    bDescriptorType         2
    wTotalLength           35
    bNumInterfaces          1
    bConfigurationValue     1
    iConfiguration          0
    bmAttributes         0xc0
      Self Powered
    MaxPower                0mA
    Interface Descriptor:
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           2
      bInterfaceClass       255 Vendor Specific Class
      bInterfaceSubClass      1
      bInterfaceProtocol      0
      iInterface              0
      Endpoint Descriptor:
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x81  EP 1 IN
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0040  1x 64 bytes
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x02  EP 2 OUT
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
Device Status:     0x0000
  (Bus Powered)
Screen
Calculator screen
Variables
Starts importing and at the end displays:
(tilp:18440): tifiles-ERROR **: string passed in 'write_string8' is too long (>n chars).
Trace/breakpoint trap (core dumped)
Applications
Does nothing
ID List
This one works okay as far as I can tell
Clock
Shows a popup and gives a console warning, but doesn't crash the program
Msg: timeout occured while reading to the device.
Cause: check that link cable is plugged and/or the calculator is ready.
System: Resource temporarily unavailable (errno = 11)
(tilp:18547): ticables-WARNING **: usb_bulk_read (No error).
EDIT: I was able to successfully back up the calculator and dump the ROM with a Silver Link cable.
