How do you add a program icon to the desktop in version 14.04? I thought you could search for the program in the Dash, then drag the icon to the desktop, but I can't get it to work. I can add it to the launcher, no problem. I un-pinned an icon from the launcher and it doesn't show up in the list of apps in the Dash unless I search for it. Is this normal? I want to put it on the Desktop, hence the above question.
Asked
Active
Viewed 4,423 times
Most of the program shortcuts (desktop files) are stored in /usr/share/applications/ folder. So, if you want to create a desktop shortcut to an application that is in the dash, open a terminal window and type in the following:
cp /usr/share/applications/nameofapp.desktop ~/Desktop/
then you need to make the shortcut executable to work. Type in the following from a terminal window to make it executable:
chmod +x ~/Desktop/nameofapp.desktop
Hope this helps!
in File Manager, I navigated to /usr/share/applications and right-clicked each icon (one at a time) and selected "copy to" and then clicked "Desktop" then "Select" ...voila! not as technical an approach, but it worked.
djlen_ny
- 11
