11
I'm trying to set up a Samba share that is only accessible by a particular user. I'd like that user to have read/write access to all files in the share.
The smb.conf file below will let me access the share through the one user 'patrick' but I can't get write access to work - I cannot modify or delete files on the mounted share via windows. The user does have the proper permissions set for the directory per below.
How can I enable read/write access? I do not want to change the directory/file permissions to 0777 like many of the other forum posts would suggest.
Directory permissions:
drwxr-xr-x   6 patrick patrick  4096 Jul  3  2015 ./
drwxr-xr-x   3 root    root     4096 Jul  1  2015 ../
drwxrwxr-x+ 15 patrick patrick 65536 Jan 22 00:01 music/
The smb.conf file:
[global]
   workgroup = WORKGROUP
        server string = %h server (Samba, Ubuntu)
#   wins support = no
   dns proxy = no
   log file = /var/log/samba/log.%m
   max log size = 1000
   syslog = 0
   panic action = /usr/share/samba/panic-action %d
   server role = standalone server
   passdb backend = tdbsam
   obey pam restrictions = yes
   unix password sync = yes
   passwd program = /usr/bin/passwd %u
   passwd chat = *Enter\snew\s*\spassword:* %n\n *Retype\snew\s*\spassword:* %n\n *password\supdated\ssuccessfully* .
   pam password change = yes
   map to guest = never
   usershare allow guests = no
[Music]
   comment = Music on Ceres
   path = /mnt/largemarge/music
   valid users = patrick
   browseable = yes
   guest ok = no
   read only = no
   create mask = 0775
   directory mask = 0755
   force user = patrick
7 Answers7
10
After hours of searching, I discovered that the share name and the share directory cannot be the same (and it's not case-sensitive, either). See this post on serverfault.
So, if I change my share name in smb.conf from:
[Music]
to
[Tunes]
I can both read and write to the share. No other changes to my smb.conf were necessary, and no need to chmod 0777.
Under linux, you need to map your system account to the samba server account.
If you are creating a new user for samba access, then enter the following commands
sudo useradd {user}
sudo passwd {user}
To map a system account to a samba user use the following command
sudo smbpasswd -a {user}
The edit the file /etc/samba/smbusers to map the system account to the samba account, where the system account references the samba account
user = "user"
Jason
I had the same problem and fixed it with the good ole Windows reboot. I did not have to use a different name.
Changes to smb.conf under Share Definitions:
read only = no
create mask = 0775
directory mask = 0775
At the end of smb.conf, I added
[sambashare]
comment = Samba on Ubuntu
path = /home/fred/sambashare
read only = no
browsable = yes
Above is just for documentation purposes to show all of the changes I made. When I tested trying to write to sambashare, the Share Definitions part was not there. That is the part I added to get everything to work.
Now, after changing the 3 directives under Share Definitions, I restarted the smb service and then tested from Win10. Failed.
Next I rebooted the Linux server and tested. Still failed. Rebooted Win10 and SUCCESS.
So if anyone else has this problem and tries what I posted, I would just restart the smb service and then reboot Windows (as usual). There is probably no need to reboot the linux server. Oh, and before attempting to write to the sambashare, I closed all File Explorer Windows and used a fresh one for each test.
Hope this works for you.
zx485
  • 2,865
sudo mount -t cifs //SMB_IP_Address/SMB_Sharename /SMB_mountpoint -o username=a_SMB_user,dir_mode=0777,file_mode=0777
Where a_SMB_user was set on the server, for the share with the option
write list=a_SMB_user
Also local file access on the shared folder from the server has 0777 as access rights on it.
In my case all the other users have RO access, by putting on the server also this option for the share:
writeable=no
Basically, my solution solves the mixed access share problem.
As a remark, this share with mixed access works fine when mounted on a Windows machine, and also in the past it worked on a CentOS machine, and does not need the dir_mode and the file_mode options to be set.
I've also documented that the Share name and Directory name cannot be the same or the share will be visible and read-only despite the permissions. When the Share name is modified to be different than the Directory (or Disk) name it will become writeable assuming it and the user have the correct permissions.
I found this with NTFS disks and folders mounted in Ubuntu that had been previously shared under NTFS using the same Share names. Win and Linux sharing tools both default to the directory or disk name for their share name during creation so the conflict is built-in by default. Simply adding a character to the Linux Share name made it writeable.
This may or may not be true if the disk or directory are not NTFS or are NTFS but have never been shared. It appears that previously-used NTFS share names are reserved when mounted in Ubuntu and Linux deals with the conflict by making the share read-only.
An NTFS directory share named \My Music simply renamed \My Muzak in Ubuntu is enough to make the directory writeable.
-1
In Homes:
# By default, the home directories are exported read-only. Change the
# next parameter to 'no' if you want to be able to write to them.
;   read only = yes
so have you tried "read only = no" to your shares? or "writeable = yes"
-1
The following command entered in a Terminal gave me write access to a Samba file share from an Ubuntu 20.04 desktop client:
sudo mount -t cifs //SMB_IP_Address/SMB_Sharename /SMB_MountPoint -o username=your_smb_username,uid=1000
Your uid may differ if you have configured multiple clients.
Eliah Kagan
  • 119,640
