I've installed Ubuntu on my laptop but didn't know that my windows OS would be removed (even tho it says so while doing this process!!!) <--Had to say this, sorry :/
...Just a Drone after all...
Now I've been trying to reinstall windows with Ubuntu already installed.
I've tried a lot of way's but I couldn't fix it. (Go figure)
(Blame the other guy) That's it :) My problem is the same as this person (Check the link) create startup disk for windows inside linux
Again when I try this step /etc/apt/sources.list.d I can not see the file colingille-freshlight-.. as u can see on the photoenter image description here
If I was you I'd start with windows and than set up a dual boot for Ubuntu...Never heard anyone to it the other way around...When you install Ubuntu it will warn you that the HDD or SSD will be losing all data...So no one can help with this, dunno about the other guy's issue but your's seems to be, well your own fault...Don't stress windows is free now so just download a new OS and start over...Maybe when you have that set up do it the right way.
Anyway this isn't going to help you much...I'll check for a link...Bet there's not a change in hell Ubuntu has the set up for that sadly...As I thought...START OVER...Ubuntu isn't a joke, people seem to forget that a lot these days.
Yes, reinstall Windows cleanly first and then install Ubuntu as dual boot.
Even if you succeeded in Windows over Ubuntu, Windows master boot record will install over GRUB and will not recognize your Ubuntu partition. Installing Ubuntu second, will install GRUB over MBR which will detect both your Ubuntu and Windows partition.
Also you have to be consistent with boot types. That is, if Windows is UEFI, Ubuntu needs to be UEFI. If Windows is legacy, Ubuntu needs to be legacy. There is the case where you can install Windows with UEFI boot, then disable UEFI, then install Ubuntu as legacy. But if you have UEFI, you should install both Windows and Ubuntu with UEFI.
brianlen
  • 101
Right click on the Win8.1_English_x64.iso file and select burn to disk. Ubuntu will burn the disk and it will be bootable. You will need to burn this to a blank DVD.
Next, use your Ubuntu installation media to boot up the computer in a live session and choose "Try ubuntu without installing".
Open up the application "Gparted", and create a partition to put windows on. The partition must be NTFS format and it must be a "primary" type partition and not "extended".
Install windows when you are done.
After you reinstall windows, run bootrepair.
mchid
  • 44,904
  • 102
  • 162
