Root does not own the /home/* folders, but what other folders does root not own?
Tim
  • 33,500
If your purpose is to find all files and directories accessible by you, use find utility with -group flag.
 sudo find / -group $USER  | less
If you want to filter out only directories, use -type flag
 sudo find / -type d -group $USER  | less
More info in man find. Ownership of files found might belong to root, but if a file belongs to your group, as well as has read permissions for your group, you can access those files
To find files owned by you , use -user flag
find / -user $USER -ls | less
On a side note, you may want to search without sudo, because if a file is owned by you but not readable by others, it may throw error for sudo
To avoid errors in the output, use 2>/dev/null redirection. Like so
find / -user $USER -ls 2> /dev/null | less
Apart from user folders that aren't root, everything it root owned. That's why you should only use su or sudo if you need to, because you can really mess things up.
