I had Steam installed and working fine on Ubuntu 15.04 x64.
I upgraded to 15.10, and Steam stopped working.
Because Steam was having trouble with the mesa-dri:i386 drivers, I uninstalled Steam with synaptic and downloaded and installed Steam.deb directly from Valve. That produced the same error message, but will launch the Steam client. I then uninstalled that again.
When I do:
sudo apt-get install steam
Reading package lists... Done
Building dependency tree
 steam:i386 : Depends: libgl1-mesa-dri:i386 but it is not going to be installed
              Depends: libgl1-mesa-glx:i386 but it is not going to be installed
I have read many posts that address this problem mostly on other version of Ubuntu, none of those solutions have solved my situation.
cat
  • 1,712
Using wine: Uninstall steam and fix any broken packages that you may have. You can so this by running sudo apt-get -f install then install wine if you do not already have it; dowload steam for Windows. and install it in wine. For more on how to install wine.
Other options:
After uninstalling the current steam installed & running
sudo -f install
add the following line to
/etc/apt/sources.list:
deb http://repo.steampowered.com/steam/ precise steam
Then run
sudo apt-get update && sudo apt-get install steam-launcher
or Get the .deb file from steams official site.
DnrDevil
  • 1,478
