I was trying to get multitouch working on my 11.10 installation. Some googling led me to believe that I should install:
xserver-xorg-input-multitouch
to do that. This seems to be incorrect and may have messed up my system.
Ever since I installed this, not only does my install still not have multi-touch, but my touch pad occasionally does not work, I have some booting freezes, and am asked to partial upgrade. (Apparently fiddling with xserver is some kind of partial upgrade, I take it?)
Anyway, before partial upgrading, I saw that this package would be uninstalled, but no new xserver-xorg-input would be installed to replace it. (However, 172 other packages will be added, including CUPS, Empathy, and gedit, which all seem to currently work fine.)
Given that it may be removing something important in xserver-xorg, and that it may be installing new(?) versions of things that already were upgraded for 11.10 and working fine (and as far as I know, /not/ removed), is it safe to do this partial upgrade or not?
(Sidenote, I've consulted Upgrade manager wants me to do a partial upgrade and Partial Upgrade and I think my case is a little different, because these cases seemed to genuinely start an upgrade and finish part-way through it, whereas I just installed an inappropriate version of something, and want to get back to the right one.)
Thanks!
Mittenchops
  • 1,640
For anyone else's benefit in a similar position: briefly, this was a mess. I had apparently blindly installed some bleeding edge repositories to update my xorg for the sake of a multitouch screen, so the partial upgrade took me into the future. And the future was a terrifying place where things didn't work.
I eventually discovered I needed to roll back xorg and xserver-xorg, by comparing my installation with a brand new ubuntu install thanks to some advice from this post.
However, since then, I still have some issues cropping up, such as an inability to take screenshots, and being unable to connect to wifi at boot without first connecting to eth0 (haven't confirmed, but I suspect it's the same lib).
I have traced these errors to xorg and also having a scary future version of libglib2 installed, namely 2.31.0 instead of 2.30.0. That has not yet been solved, but has been posted as its own question here.
The short answer I will say, then, in response to this question is: NO, DO NOT PARTIAL UPGRADE! And more importantly, if you're seeking multi-touch, watch which repositories you install to get it---don't just follow forums. There is a known bug with xorg-edgers that pushes you down to unity-2d, and in my experience, that caused major dependency problems I have yet to resolve.
Mittenchops
  • 1,640
