I am currently trying to deploy an Openstack Cloud using Ubuntu's autopilot test drive. I have followed the instructions in http://www.ubuntu.com/download/cloud/install-autopilot-testdrive.
They deployment is made using KVM as the compute service, vSwitch as the network service, swift as the object storage service, and iSCSI as the block storage service. There are 6 nodes on my network which follow the simple naming convention "node-x". Seven, counting the controller node. The network they are all connected to is the 10.0.0.0/24.
However, when I enter Landscape to actually deploy the region, the process fails at 96%. The processes which fail are:
  • Deploying 'mysql' service
  • Add unit to 'mysql' service on 'node-1.myautopilot
  • Creating a Landscape admin user
I imagine only one of the three is the actual root of the problem, but I have little to no experience viewing the logs (not to mention, there are several of them). The errors I have found in the logs are the following:
juju-sync.log
Jan 18 12:13:11 juju-sync-1 INFO  Unit mysql/0 has been updated: address = 10.0.0.82, machine_id = 0/lxc/5, state = error, state_info = hook failed: "shared-db-relation-changed"
all-machines.log
unit-mysql-0[912]: 2016-01-18 12:13:05 ERROR juju.worker.uniter.operation runhook.go:107 hook "shared-db-relation-changed" failed: exit status 1
In fact there were many more errors, all of them relating to no relation id specified
job-handler.log
Jan 18 10:58:13 job-handler-1 ERR Got error while handling job#012Traceback (most recent call last):#012 File "/usr/lib/python2.7/dist-packages/twisted/internet/defer.py", line 423, in errback#012 self._startRunCallbacks(fail)#012 File "/usr/lib/python2.7/dist-packages/twisted/internet/defer.py", line 490, in _startRunCallbacks#012 self._runCallbacks()#012 File "/usr/lib/python2.7/dist-packages/twisted/internet/defer.py", line 577, in _runCallbacks#012 current.result = callback(current.result, *args, **kw)#012 File "/usr/lib/python2.7/dist-packages/twisted/internet/defer.py", line 1155, in gotResult#012 _inlineCallbacks(r, g, deferred)#012--- ---#012 File "/usr/lib/python2.7/dist-packages/twisted/internet/defer.py", line 1097, in _inlineCallbacks#012 result = result.throwExceptionIntoGenerator(g)#012 File "/usr/lib/python2.7/dist-packages/twisted/python/failure.py", line 389, in throwExceptionIntoGenerator#012 return g.throw(self.type, self.value, self.tb)#012 File "/opt/canonical/landscape/canonical/landscape/model/activity/jobs.py", line 18, in run#012 yield self._update_activity(account_id, activity_id)#012 File "/usr/lib/python2.7/dist-packages/twisted/python/threadpool.py", line 196, in _worker#012 result = context.call(ctx, function, *args, **kwargs)#012 File "/usr/lib/python2.7/dist-packages/twisted/python/context.py", line 118, in callWithContext#012 return self.currentContext().callWithContext(ctx, func, *args, **kw)#012 File "/usr/lib/python2.7/dist-packages/twisted/python/context.py", line 81, in callWithContext#012 return func(*args,**kw)#012 File "/usr/lib/python2.7/dist-packages/storm/twisted/transact.py", line 76, in _wrap#012 result = function(*args, **kwargs)#012 File "/opt/canonical/landscape/canonical/landscape/model/activity/jobs.py", line 28, in _update_activity#012 activity._update_progress_after_child_changed()#012exceptions.AttributeError: 'NoneType' object has no attribute '_update_progress_after_child_changed'
I have made sure that all VMs have sufficient resources allocated (they did from the start, as I am using the VM templates provided by Ubuntu). Furthermore, they can all access the internet.
If additional information is required, I will supply it as soon as possible.
Has anyone encountered this problem and knows how to solve it? Or, in any case, any further debugging steps I can take to find a solution to the problem?
Thank you.
P.S. If this question doesn't belong on this platform, I apologize and please redirect me to the relevant one.
Can you please file a bug and attach the full tarball of logs that the Autopilot surfaces in the UI?
