My goal here is to run the cmatrix script and lock the desktop simultaneously, so that cmatrix will be shown as a screensaver until I come back and unlock the computer.
My script looks like this:
gnome-screensaver-command -l & sudo openvt -ws cmatrix
Now I wanted to make the script be able to run without the need to input the sudo password everytime, so I changed the sudoers file (like this). It is working if I run it in the terminal, so far so good.
Then I added it to the PATH, because I wanted to bind it to the global shortcut Ctrl+Alt+L, but it doesn't work if I invoke it via the shortcut. The desktop just flashes for a split second, like it wanted to show cmatrix, but then it goes straight to the unlock screen.
I figured out that the part with openvt isn't working like it should, even if it is the only thing in the script.
Any ideas how to accomplish what I want?
EDIT: In the split second when the desktop flashes, I managed to read this on the screen:
Error opening terminal: unknown
lmazgon
  • 164
Actually now I found the solution myself - the problem and the solution are the same as in this question. I just had to add this line into my script:
export TERM=xterm
lmazgon
  • 164
Take look at this thread: https://unix.stackexchange.com/questions/91541/why-is-path-reset-in-a-sudo-command
Your PATH is being reset when you issue a sudo command, so evil hacker could not change and point it to malicious cmatrix script. So modify your secure path or append exact location of your cmatrix program to the sudo command.
nsilent22
  • 258
