Unfortunately I need to install and use IE...I'm using that guide given here. But from terminal when I try so launch using ./ies4linux I always obtain this error:
The program 'ies4linux-gtk.py' received an X Window System error.
This probably reflects a bug in the program.
The error was 'RenderBadPicture (invalid Picture parameter)'.
(Details: serial 6659 error_code 143 request_code 139 minor_code 10)
(Note to programmers: normally, X errors are reported asynchronously;
that is, you will receive the error a while after causing it.
To debug your program, run it with the --sync command line
option to change this behavior. You can then get a meaningful
backtrace from your debugger if you break on the gdk_x_error() function.)
Can someone help me? Thanks!!
Used ./ies4linux --no-gui
IEs4Linux 2 is developed to be used with recent Wine versions (0.9.x). It seems that you are using an old version. It's recommended that you update your wine to the latest version (Go to: winehq.com).
IEs4Linux will:
- Install Internet Explorers: 6.0
- Using IE locale: EN-US
- Install Adobe Flash 9.0
- Install everything at: /home/giovanni/.ies4linux
[ OK ]
Downloading everything we need
Downloading from microsoft.com:
DCOM98.EXE
0% mfc42.cab 249973USA8.exe
ADVAUTH.CAB
CRLUPD.CAB
HHUPD.CAB
IEDOM.CAB
IE_EXTRA.CAB
IE_S1.CAB
IE_S2.CAB
IE_S5.CAB
IE_S4.CAB
IE_S3.CAB
IE_S6.CAB
SETUPW95.CAB
FONTCORE.CAB
FONTSUP.CAB
VGX.CAB
SCR56EN.CAB
Downloading from macromedia.com:
swflash.cab
[ OK ]
Installing IE 6
Initializing
Creating Wine Prefix
Extracting CAB files
Installing IE 6
Installing DCOM98
Installing TTF Fonts
Installing ActiveX MFC42
/home/giovanni/.ies4linux/downloads/mfc42.cab: No such file or directory
An error occured when trying to cabextract some files.
Doing
wget -q "http://deb.playonlinux.com/public.gpg" -O- | sudo apt-key add -
sudo wget http://deb.playonlinux.com/playonlinux_precise.list -O /etc/apt/sources.list.d/playonlinux.list
sudo apt-get update && sudo apt-get install playonlinux
I get again
giovanni@giovanni-X551CAP:~$ cd ies4linux-*
giovanni@giovanni-X551CAP:~/ies4linux-2.99.0.1$ ./ies4linuxIEs4Linux 2 is developed to be used with recent Wine versions (0.9.x). It seems that you are using an old version. It's recommended that you update your wine to the latest version (Go to: winehq.com).
(Details: serial 2720 error_code 143 request_code 139 minor_code 10)
I Changed link as says in the comment "Line 75 of install.sh from the latest package reads:
download http://activex.microsoft.com/controls/vc/mfc42.cab
The server answers with:
Access Denied You don't have permission to access "http://activex.microsoft.com/controls/vc/mfc42.cab" on this server.
Reference #18.ecdd4e17.1453232252.16053044 If you have the file or can find it somewhere else just replace the URL and it should be able to continue the installation."
But now i have....
The program 'ies4linux-gtk.py' received an X Window System error. This probably reflects a bug in the program. The error was 'RenderBadPicture (invalid Picture parameter)'. (Details: serial 2920 error_code 143 request_code 139 minor_code 6) (Note to programmers: normally, X errors are reported asynchronously; that is, you will receive the error a while after causing it. To debug your program, run it with the --sync command line option to change this behavior. You can then get a meaningful backtrace from your debugger if you break on the gdk_x_error() function.)
