Wi-Fi network does not connect right after system started, but when I restart my router it becomes working well without failures. What can be a cause of this problem?
P.S. Such behavior was noticed on every device such as tablet, smartphone, PC (Linux/Windows).
Router model: tl-wr740n/tl-wr740nd
Other info: http://paste.ubuntu.com/14545476/
Asked
Active
Viewed 46 times
Praytic
- 339
- 1
- 3
- 8
If it was not consistent with all devices, I would say that this is might be a driver issue. The RTL8192CU does have a history of issues with a few linux kernel versions.
However, you might want to take a look at this.
I would suggest to change the TKIP encryption into AES and switch to WPA2 instead of WPA.
* Update *
Sorry I missed that you're using CCMP.
However, I have noticed that there are two other networks in the area that use the same channel(11) that you are using. Try to change it to 8 or 6 and see how it goes.
