When attempting to install Dolphin-Emu, I have come across a un-met dependences that are preventing the installation. I installed Dolphin-Emu as a PPA, so I could manually install the package. Every time I attempt to install, this is the code that I am using, and the message I get.
$ sudo apt-get install dolphin-emu
Reading package lists... Done
Building dependency tree
    dolphin-emu : Depends: libstdc++6 (>= 4.9) but 4.8.4-2ubuntu1~14.04 is to be installed
Any and all help would be appriciated.
According to the install guide available online, the following should work:
sudo add-apt-repository ppa:dolphin-emu/ppa
sudo apt-get update
sudo apt-get install dolphin-emu-master
You could also try a sudo apt-get upgrade immediately after the update command (these two are usually good commands to try when apt is misbehaving/having trouble on ubuntu).
UPDATE: also according to the dolphin install guide, if running ubuntu 12.04 or 14.04, run these commands first:
sudo add-apt-repository ppa:dolphin-emu/gcc-for-dolphin
sudo apt-get update
tniles
  • 284
Before you try something else, try to follow the instruction from previous answer ppa, it said:
Unofficial builds for Dolphin Wii/Gamecube Emulator.
Install the dolphin-emu package for the latest stable release of Dolphin.
Install the dolphin-emu-master package for weekly builds that include the latest upstream changes from git.
The dolphin-emu-triforce package will allow you play Triforce games, as well Wii/Gamecube games. It's based on the old Triforce fork (4.0-315).
You'll need to enable the Universe repo before install Dolphin.
For Ubuntu 12.04 and 14.04 users: dolphin-emu-master needs an updated libstdc++6 (>=4.9), so install this PPA first:
https://launchpad.net/~dolphin-emu/+archive/ubuntu/gcc-for-dolphin
It will update libstdc++6 in your system to version 4.9.2, so be careful.
If you found a problem to update libstdc++6, use this PPA instead:
https://launchpad.net/~ubuntu-toolchain-r/+archive/ubuntu/test
THERE'S NO 32-bit (i386) BUILDS ANYMORE: https://dolphin-emu.org/blog/2014/05/19/obituary-32bit/
ARMv8/AArch64/arm64 packages now ;)
so if you have problem with libstdc++6 try :
  1. heed the warning then add ppa using add-apt-repository from https://launchpad.net/~dolphin-emu/+archive/ubuntu/gcc-for-dolphin
  2. do sudo apt-get update
  3. do sodo apt-get upgrade
then try to install it again, if that doesn't works try:
  1. add ppa from https://launchpad.net/~ubuntu-toolchain-r/+archive/ubuntu/test
  2. then do sudo apt-get update and sudo apt-get upgrade
then try to install dolphin-emu again. but, as readme said, this will update libstdc++6 to version 4.9.2 so it is up to you.
