I would like to know if the Ubuntu OS can run Windows applications.
Such as .exe, .dll files.
Or games like Call of Duty.
Without needing to download any application such as wine.
My guess is it doesn't but just to be sure I'll ask.
BiiX
  • 111
Well, it's always tough to explain Linux to Windows newcomers. First tip ever: forget Windows. Linux is not and will never be Windows, just as Windows is not and will never be Linux. They are different. Period. Now the whole thing:
  • Linux is an Unix-like system. What? Unix-like? Unix is an ancient operating system born in the 60's, when computers were huge and men were men, writing their own hardware drivers. Unix had a singular file system scheme and an amazing set of utilities. Unix-like systems are the ones that follow these characteristics. Nowadays Unix is extinct, but its soul is held in lots of Unix-like systems, such as the BSD's, Apple's Mac OSX, Minix and Linux. We can say most of the existing OSs today are either Windows NT based or Unix-like.
  • Windows systems need file extensions to handle their files. They simply do not know what to do with a file without an extension. Those include .exe (binaries/executables), .txt (text), .bat (batch scripts), among lots of others.
  • Most Unix-like systems do not need any file extensions. Instead of relying on the filename, there is a thing called "MIME" (Multipurpose Internet Mail Extension). It's basically a bit of code written directly in the beginning of every file. It tells the system how to handle it. However we do use extensions sometimes just to tell the user if a file is, e.g., either a shell script (.sh) or a text file (.txt), even though it's not necessary.
  • There is a thing called kernel. A kernel is a piece of software which makes the "translation" from software language to hardware language and vice-versa. It's essential to any Operating System: no kernel, no OS. Windows uses the NT kernel, while Ubuntu uses the Linux kernel (that's why it's a Linux distribution). When a developer makes a program he uses a programming language, and this language must be translated to binary (computer language) before this program can run. This process is called "compiling". But each kernel has its own way of translating a program to computer language, so programs compiled for NT can't run natively on Linux, and vice -versa.
  • There is a very popular program for Unix-like Operating Systems called "Wine". Wine creates a compatibility layer so these OSs can run Windows programs. What Wine does is translating the program's requests to Linux language. You can install it in Ubuntu through the Software Center or through command line with the command sudo apt-get install wine. Right-click the .exe file you want to run and click "open with Wine". Note that some applications may not work.
  • And last, but not less important (actually the most important one), there are ALWAYS free, open-source, native alternatives and solutions for Windows programs in Linux. Don't forget that!!!
P.S.: sorry for so much "language" and "translation" examples, it's the best way I found to explain.
Eduardo Cola
  • 5,876
  • 20
  • 33
It is not as simple as that. While software written for Linux generally does not use the .exe extension, and dynamically loaded libraries typically have .so, more often with a version after that for stable libraries, there are some pieces of software which do use the .exe or .dll extensions, though they are not necessarily programs for Windows. For example, things written in the C# programming language, will have these file extensions.
You cannot directly run Windows programs on Ubuntu (or other versions of Linux). Some may be usable through the Wine translation layer that can be installed and used. However, more and more applications are becoming available for Ubuntu, and Linux in general, every day.
dobey
  • 41,650
