I had compiled many C programs together, and each of the file had a .gch created. Now I did not want the .gch files so I decided to delete them. But it would take lots of time using rm for deleting each file. So is there a way to remove files with the same extension in one go?
NOTE: I work in Ubuntu 14.04. I want the solution to be in shell or terminal. The question is not a duplicate as I want to use rm only.
Box Box Box Box
  • 219
  • 13
To remove files with the same extension in one-go, just use find command.
find /path/to/directory -type f -iname '*.gch' -delete
  • -type tells find if you are searching for files or directories, here:
    f = file
    d = directory
  • iname tells find about the name of the file you are looking for.
    Note: name does the same thing but iname is recommended because it ignores cases whereas name doesn't.
  • -delete deletes those files
kos
  • 41,268
Raphael
  • 8,135
easily use the expansion"*":
rm /path-to-directory/*.gch
This what is called filename expansion which use some special characters called wildcards.
suppose you have a directory containing the files (file, file0, file1, file01)
Some know wildcards:
The question mark (?) is a special character that causes the shell to generate filenames. It matches any single character in the name of an existing file.
example:
ls file?
The shell expands the "file?" argument and generates a list of files in the working directory that have names composed of "file" followed by any single character.
Then the output would be file0 and file1
The asterisk (*) performs a function similar to that of the question mark but matches any number of characters, including zero characters, in a filename.
now the output of the command:
ls file*
would be file, file0, file1 and also file01
The [ ] Special Characters causes the shell to match filenames containing the individual characters within the brackets.
for example the output of the command:
ls file[01]*
would be:
file0 file1 file01
This is just a simple introduction for shell expansion, you can read more :
Maythux
  • 87,123
Simply type the following command in terminal (shell)
rm -rf  /path/to/files/*.<extension>
Be careful with the -f parameter. It will not warn before deleting.
Sohail
  • 111
If you are using C and Makefiles, you can also make a .PHONY recipe target and rm by default and add the byproduct "cruft" files that one deletes from a clean source directory. You still use the wildcard * token.
make clean
for example
   .PHONY clean
    clean:
         rm -f *.gch  *.o *.temp *.log
then you have multiplied your productivity in cruft elimination.
daemondave
  • 171
