I am a Ubuntu newbie. While installing Laravel using terminal, I came across this issue:
roger@roger-P580:/etc/apache2/sites-available$ cd /var/www/laravel
roger@roger-P580:/var/www/laravel$ a2ensite laravel.example.com
ERROR: Site laravel.example.com does not exist!
What am I supposed to do?
roggie
You asked "problem installing laravel", in that case simply do steps 1 to 3 correctly from this guide : Refer to this working guide to install laravel,
Otherwise if those steps are clear, you might refer the last steps- Assuming you created a virtual host, you have to reload the service :
$ sudo service apache2 reload
And after that put up a port for accesing it thru browser.
sudo echo "127.0.0.1 laravel.example.com" >> /etc/hosts
