-1
I have an image hovering in my lock-screen that I can't remove. I think I put it there with Ubuntu-tweak but I have already uninstalled it.
Any ideas on how to remove it?
I really hope this is the only issue it left me with but only time will tell.
edit - more details
lock-screen
I think i might have replaced the "Ubuntu 14.04" logo with Darth lighting a smoke.
A - Reinstalled and set to default, and then uninstalled it again
  • The first part is solved but now it seems like I can't make any changes in my standard appearance settings.
So the new question is how to remove all traces of Ubuntu Tweak?
Jan
  • 31
Uninstall the tweak tools using APT per the post by DnrDevil. I believe what you are dealing with is a bug in 14.04. Are you running Gnome? If so try this command and you should be able to set the wallpaper through the gnome GUI.
gsettings set org.gnome.settings-daemon.plugins.background active true
Also if you are missing desktop icons on top of this run this one:
gsettings set org.gnome.desktop.background show-desktop-icons true
Source: Wallpaper is not changing and right click does not work on desktop in Ubuntu 14.04
Open a terminal (Ctl + Alt+T) and type sudo apt-get purge ubuntu-tweak and confirm. This will remove all ubuntu tweak pakages you can also run sudo apt-get autoremove after this to remove all resources for the application.
DnrDevil
  • 1,478
