As a follow-up to this question, the very useful and small birthday (and more) reminder tool Gbirthday does not seem not work with Unity. Is there a way to tweak this, so Gbirthday works in Ubuntu with Unity?
Normally there would be a small icon in the panel, but I guess Unity does not like "foreign" items in the panel.
Kulfy
  • 18,154
Filbuntu
  • 13,891
You can make any program that used to use the old notification system in Gnome 2.0 (the panel before Unity) show up in the new panel in 11.04 and 11.10 by whitelisting it. There are directions in this blog post:
http://www.webupd8.org/2011/04/how-to-re-enable-notification-area.html
If you don't like the command line, skip down to section B in the instructions (B. Using a GUI).
In the meantime I found another solution, not as elegant as the above:
If there is a Gnome Panel applet that you absolutely must use and it isn't feasible to get an indicator to replace it, then this might be a workaround: Install xfce4-panel (see Can I use GNOME applets in Unity?)
Then I added xcfe4-panel and gbirthday to the startup applications. After restart: I chose to get an empty panel, added the notification area to the panel and set it to Auto-hide. Afterwards arranged the panel in such a way as to not bother other parts of your system, i.e in the lower-right corner. This worked for me although I hope the workaround from Omegamormegil will for me as well.
Filbuntu
  • 13,891
