18
I downloaded JabRef-3.2.jar. I can execute it from the command line:
java -jar JabRef-3.2.jar
which works fine. But I would like to have a Launcher in my start menu, if possible with an appropriate icon. How can I do this?
Note: I am running Xubuntu 15.04.
a06e
  • 14,233
First, change directory
cd ~/.local/share/applications
Then, open nano editor:
nano JabRef.desktop
Add the following to the file:
[Desktop Entry]
Type=Application
Terminal=false
Icon=PATH TO YOUR ICON
Exec=java -jar /path/to/your/JabRef-3.2.jar
Name=NAME YOUR DESKTOP ICON
Then, Ctrl + X --> Y --> Enter.
It should create an icon for you to launch, just search for it in Menu.
Raphael
  • 8,135
Desktop, File Browser & Command Line
Personally, I have created a /home/bin directory to keep scripts for occasions like this.
$ sudo mkdir /home/bin
Just make sure that for every user the directory /home/bin is accessible:
$ sudo chmod +rx /home/bin
Furthermore the new directory should be listed as PATH="/home/bin:$PATH" in the ~/.profile file of every user or wherever PATH happens to be defined on your system.
Save below bash script as jabref in the newly created /home/bin/ directory.
#!/usr/bin/env bash
INSTALLDIR='/home/opt/jabref'
Run the latest version.
java -jar $(ls -1v $INSTALLDIR/JabRef*.jar |tail -n 1) $@ &
The bash script should be made executable with:
$ sudo chmod +x jabref
The script will open the latest version of JabRef*.jav previously saved in /home/opt/jabref/ with any yet existing desktop launcher or any file browser integration. Simply typing jabref at the command line also works.
Serge Stroobandt
  • 5,719
  • 54
  • 59
