I'm not sure how to solve this problem as both 15.04 and 15.10 with systemd get me only to an emergency shell whereas upstart works just fine. Having struggled with this for a whole version, help would be appreciated.
Here the last few lines of my dmesg:
[  100.633980] systemd[1]: Accepted new private connection.
[  100.634001] systemd-cgroups-agent[792]: Sent message type=signal sender=n/a destination=n/a object=/org/freedesktop/systemd1/agent interface=org.freedesktop.systemd1.Agent member=Released cookie=1 reply_cookie=0 error=n/a
[  100.634005] systemd[1]: Got disconnect on private connection.
[  100.634180] systemd[1]: Got message type=signal sender=n/a destination=n/a object=/org/freedesktop/systemd1/agent interface=org.freedesktop.systemd1.Agent member=Released cookie=1 reply_cookie=0 error=n/a
[  100.634269] systemd[1]: Got disconnect on private connection.
[  100.636283] systemd[1]: Received SIGCHLD from PID 751 (resolvconf).
[  100.636293] systemd[1]: Child 751 (resolvconf) died (code=exited, status=0/SUCCESS)
[  100.636307] systemd[1]: resolvconf.service: Child 751 belongs to resolvconf.service
[  100.636312] systemd[1]: resolvconf.service: Main process exited, code=exited, status=0/SUCCESS
[  100.636382] systemd[1]: resolvconf.service: Changed running -> exited
[  100.636386] systemd[1]: resolvconf.service: cgroup is empty
[  100.637035] systemd[1]: Accepted new private connection.
[  100.637071] systemd-cgroups-agent[808]: Sent message type=signal sender=n/a destination=n/a object=/org/freedesktop/systemd1/agent interface=org.freedesktop.systemd1.Agent member=Released cookie=1 reply_cookie=0 error=n/a
[  100.637077] systemd[1]: Got message type=signal sender=n/a destination=n/a object=/org/freedesktop/systemd1/agent interface=org.freedesktop.systemd1.Agent member=Released cookie=1 reply_cookie=0 error=n/a
[  100.637156] systemd[1]: Got disconnect on private connection.
[  100.643279] audit: type=1400 audit(1452853904.083:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/lightdm/lightdm-guest-session" pid=822 comm="apparmor_parser"
[  100.643283] audit: type=1400 audit(1452853904.083:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="chromium" pid=822 comm="apparmor_parser"
[  100.644807] audit: type=1400 audit(1452853904.083:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/sbin/dhclient" pid=822 comm="apparmor_parser"
[  100.644811] audit: type=1400 audit(1452853904.083:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/NetworkManager/nm-dhcp-client.action" pid=822 comm="apparmor_parser"
[  100.644814] audit: type=1400 audit(1452853904.083:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/NetworkManager/nm-dhcp-helper" pid=822 comm="apparmor_parser"
[  100.644817] audit: type=1400 audit(1452853904.083:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/connman/scripts/dhclient-script" pid=822 comm="apparmor_parser"
[  100.651499] audit: type=1400 audit(1452853904.091:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/bin/evince" pid=822 comm="apparmor_parser"
[  100.651503] audit: type=1400 audit(1452853904.091:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="sanitized_helper" pid=822 comm="apparmor_parser"
[  100.651506] audit: type=1400 audit(1452853904.091:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/bin/evince-previewer" pid=822 comm="apparmor_parser"
[  100.651508] audit: type=1400 audit(1452853904.091:11): apparmor="STATUS" operation="profile_load" profile="unconfined" name="sanitized_helper" pid=822 comm="apparmor_parser"
[  100.651700] systemd-journald[471]: Failed to forward syslog message: Connection refused
[  100.658209] systemd-journald[471]: Failed to forward syslog message: Connection refused
[  100.660713] systemd-journald[471]: Failed to forward syslog message: Connection refused
[  100.660786] systemd[1]: Received SIGCHLD from PID 737 (apparmor).
[  100.660797] systemd[1]: Child 737 (apparmor) died (code=exited, status=0/SUCCESS)
[  100.660814] systemd[1]: apparmor.service: Child 737 belongs to apparmor.service
[  100.660821] systemd[1]: apparmor.service: Control process exited, code=exited status=0
[  100.660836] systemd[1]: apparmor.service: Got final SIGCHLD for state start.
[  100.660951] systemd[1]: apparmor.service: Changed start -> exited
[  100.660955] systemd[1]: apparmor.service: Job apparmor.service/start finished, result=done
[  100.660960] systemd[1]: Started LSB: AppArmor initialization.
[  100.661034] systemd[1]: apparmor.service: cgroup is empty
[  100.661228] systemd[1]: networking.service: About to execute: /etc/init.d/networking start
[  100.661324] systemd[1]: networking.service: Forked /etc/init.d/networking as 828
[  100.661366] systemd[1]: networking.service: Changed dead -> start
[  100.661372] systemd[1]: Starting LSB: Raise network interfaces....
[  100.661701] systemd[828]: networking.service: Executing: /etc/init.d/networking start
[  100.662192] systemd[1]: Accepted new private connection.
[  100.662252] systemd-cgroups-agent[827]: Sent message type=signal sender=n/a destination=n/a object=/org/freedesktop/systemd1/agent interface=org.freedesktop.systemd1.Agent member=Released cookie=1 reply_cookie=0 error=n/a
[  100.662323] systemd[1]: Got message type=signal sender=n/a destination=n/a object=/org/freedesktop/systemd1/agent interface=org.freedesktop.systemd1.Agent member=Released cookie=1 reply_cookie=0 error=n/a
[  100.662360] systemd[1]: apparmor.service: cgroup is empty
[  100.662382] systemd[1]: Got disconnect on private connection.
[  100.665820] systemd-journald[471]: Failed to forward syslog message: Connection refused
[  100.691237] systemd-journald[471]: Failed to forward syslog message: Connection refused
[  100.691276] systemd[1]: Received SIGCHLD from PID 828 (networking).
[  100.691288] systemd[1]: Child 828 (networking) died (code=exited, status=0/SUCCESS)
[  100.691305] systemd[1]: networking.service: Child 828 belongs to networking.service
[  100.691309] systemd[1]: networking.service: Control process exited, code=exited status=0
[  100.691322] systemd[1]: networking.service: Got final SIGCHLD for state start.
[  100.691338] systemd[1]: networking.service: Changed start -> running
[  100.691342] systemd[1]: networking.service: Job networking.service/start finished, result=done
[  100.691349] systemd[1]: Started LSB: Raise network interfaces..
[  100.691528] systemd[1]: network.target changed dead -> active
[  100.691531] systemd[1]: network.target: Job network.target/start finished, result=done
[  100.691535] systemd[1]: Reached target Network.
[  100.691548] systemd[1]: network-online.target changed dead -> active
[  100.691550] systemd[1]: network-online.target: Job network-online.target/start finished, result=done
[  100.691553] systemd[1]: Reached target Network is Online.
[  100.691573] systemd[1]: Assertion 'r >= 0' failed at ../src/libsystemd/sd-event/sd-event.c:484, function source_io_unregister(). Ignoring.
[  100.691580] systemd[1]: Startup finished in 10.490s (kernel) + 1min 30.231s (userspace) = 4min 57.942s.
[  100.694597] systemctl[922]: Showing one /org/freedesktop/systemd1/unit/ntp_2eservice
[  100.695050] systemd[1]: Accepted new private connection.
[  100.695102] systemctl[922]: Sent message type=method_call sender=n/a destination=org.freedesktop.systemd1 object=/org/freedesktop/systemd1/unit/ntp_2eservice interface=org.freedesktop.DBus.Properties member=GetAll cookie=1 reply_cookie=0 error=n/a
[  100.695144] systemd[1]: Got message type=method_call sender=n/a destination=org.freedesktop.systemd1 object=/org/freedesktop/systemd1/unit/ntp_2eservice interface=org.freedesktop.DBus.Properties member=GetAll cookie=1 reply_cookie=0 error=n/a
[  100.695182] systemd[1]: ntp.service: Failed to load configuration: No such file or directory
[  100.695350] systemd[1]: Sent message type=method_return sender=n/a destination=n/a object=n/a interface=n/a member=n/a cookie=1 reply_cookie=1 error=n/a
[  100.695363] systemd[1]: ntp.service: Collecting.
[  100.695370] systemd[1]: Sent message type=signal sender=n/a destination=n/a object=/org/freedesktop/systemd1 interface=org.freedesktop.systemd1.Manager member=UnitNew cookie=2 reply_cookie=0 error=n/a
[  100.695374] systemd[1]: Sent message type=signal sender=n/a destination=n/a object=/org/freedesktop/systemd1 interface=org.freedesktop.systemd1.Manager member=UnitRemoved cookie=3 reply_cookie=0 error=n/a
[  100.695379] systemctl[922]: Got message type=method_return sender=n/a destination=n/a object=n/a interface=n/a member=n/a cookie=1 reply_cookie=1 error=n/a
[  100.695557] systemd[1]: Got disconnect on private connection.
[  100.696711] systemd[740]: emergency.service: Executing: /bin/plymouth --wait quit
[  100.696807] systemd[1]: Accepted new private connection.
[  100.696854] systemctl[923]: Sent message type=method_call sender=n/a destination=org.freedesktop.systemd1 object=/org/freedesktop/systemd1 interface=org.freedesktop.DBus.Properties member=Get cookie=1 reply_cookie=0 error=n/a
[  100.696894] systemd[1]: Got message type=method_call sender=n/a destination=org.freedesktop.systemd1 object=/org/freedesktop/systemd1 interface=org.freedesktop.DBus.Properties member=Get cookie=1 reply_cookie=0 error=n/a
[  100.696906] systemd[1]: Sent message type=method_return sender=n/a destination=n/a object=n/a interface=n/a member=n/a cookie=1 reply_cookie=1 error=n/a
[  100.696942] systemctl[923]: Got message type=method_return sender=n/a destination=n/a object=n/a interface=n/a member=n/a cookie=1 reply_cookie=1 error=n/a
[  100.696982] systemd[1]: Got disconnect on private connection.
[  100.697687] systemctl[924]: Calling manager for StopUnit on ntp.service, ignore-dependencies
[  100.698157] systemd[1]: Accepted new private connection.
[  100.698217] systemctl[924]: Sent message type=method_call sender=n/a destination=org.freedesktop.systemd1 object=/org/freedesktop/systemd1 interface=org.freedesktop.systemd1.Manager member=StopUnit cookie=1 reply_cookie=0 error=n/a
[  100.698268] systemd[1]: Got message type=method_call sender=n/a destination=org.freedesktop.systemd1 object=/org/freedesktop/systemd1 interface=org.freedesktop.systemd1.Manager member=StopUnit cookie=1 reply_cookie=0 error=n/a
[  100.698290] systemd[1]: ntp.service: Failed to load configuration: No such file or directory
[  100.698302] systemd[1]: Sent message type=error sender=n/a destination=n/a object=n/a interface=n/a member=n/a cookie=1 reply_cookie=1 error=Unit ntp.service not loaded.
[  100.698305] systemd[1]: Failed to process message [type=method_call sender=n/a path=/org/freedesktop/systemd1 interface=org.freedesktop.systemd1.Manager member=StopUnit signature=ss]: Unit ntp.service not loaded.
[  100.698307] systemd[1]: ntp.service: Collecting.
[  100.698313] systemd[1]: Sent message type=signal sender=n/a destination=n/a object=/org/freedesktop/systemd1 interface=org.freedesktop.systemd1.Manager member=UnitNew cookie=2 reply_cookie=0 error=n/a
[  100.698317] systemd[1]: Sent message type=signal sender=n/a destination=n/a object=/org/freedesktop/systemd1 interface=org.freedesktop.systemd1.Manager member=UnitRemoved cookie=3 reply_cookie=0 error=n/a
[  100.698318] systemctl[924]: Got message type=error sender=n/a destination=n/a object=n/a interface=n/a member=n/a cookie=1 reply_cookie=1 error=Unit ntp.service not loaded.
[  100.698322] systemctl[924]: Failed to stop ntp.service: Unit ntp.service not loaded.
[  100.698348] systemctl[924]: Sent message type=method_call sender=n/a destination=org.freedesktop.systemd1 object=/org/freedesktop/systemd1/unit/ntp_2eservice interface=org.freedesktop.DBus.Properties member=Get cookie=2 reply_cookie=0 error=n/a
[  100.698371] systemd[1]: Got message type=method_call sender=n/a destination=org.freedesktop.systemd1 object=/org/freedesktop/systemd1/unit/ntp_2eservice interface=org.freedesktop.DBus.Properties member=Get cookie=2 reply_cookie=0 error=n/a
[  100.698392] systemd[1]: ntp.service: Failed to load configuration: No such file or directory
[  100.698404] systemd[1]: Sent message type=method_return sender=n/a destination=n/a object=n/a interface=n/a member=n/a cookie=4 reply_cookie=2 error=n/a
[  100.698407] systemd[1]: ntp.service: Collecting.
[  100.698413] systemd[1]: Sent message type=signal sender=n/a destination=n/a object=/org/freedesktop/systemd1 interface=org.freedesktop.systemd1.Manager member=UnitNew cookie=5 reply_cookie=0 error=n/a
[  100.698417] systemctl[924]: Got message type=method_return sender=n/a destination=n/a object=n/a interface=n/a member=n/a cookie=4 reply_cookie=2 error=n/a
[  100.698418] systemd[1]: Sent message type=signal sender=n/a destination=n/a object=/org/freedesktop/systemd1 interface=org.freedesktop.systemd1.Manager member=UnitRemoved cookie=6 reply_cookie=0 error=n/a
[  100.698427] systemctl[924]: Sent message type=method_call sender=n/a destination=org.freedesktop.systemd1 object=/org/freedesktop/systemd1/unit/ntp_2eservice interface=org.freedesktop.DBus.Properties member=Get cookie=3 reply_cookie=0 error=n/a
[  100.698432] systemd[1]: Got message type=method_call sender=n/a destination=org.freedesktop.systemd1 object=/org/freedesktop/systemd1/unit/ntp_2eservice interface=org.freedesktop.DBus.Properties member=Get cookie=3 reply_cookie=0 error=n/a
[  100.698446] systemd[1]: ntp.service: Failed to load configuration: No such file or directory
[  100.698454] systemd[1]: Sent message type=method_return sender=n/a destination=n/a object=n/a interface=n/a member=n/a cookie=7 reply_cookie=3 error=n/a
[  100.698457] systemd[1]: ntp.service: Collecting.
[  100.698461] systemd[1]: Sent message type=signal sender=n/a destination=n/a object=/org/freedesktop/systemd1 interface=org.freedesktop.systemd1.Manager member=UnitNew cookie=8 reply_cookie=0 error=n/a
[  100.698466] systemd[1]: Sent message type=signal sender=n/a destination=n/a object=/org/freedesktop/systemd1 interface=org.freedesktop.systemd1.Manager member=UnitRemoved cookie=9 reply_cookie=0 error=n/a
[  100.698468] systemctl[924]: Got message type=method_return sender=n/a destination=n/a object=n/a interface=n/a member=n/a cookie=7 reply_cookie=3 error=n/a
[  100.698518] systemd[1]: Got disconnect on private connection.
[  100.699756] systemd-journald[471]: Failed to forward syslog message: Connection refused
[  100.705302] systemctl[945]: Showing one /org/freedesktop/systemd1/unit/ntp_2eservice
[  100.705807] systemd[1]: Accepted new private connection.
[  100.705865] systemctl[945]: Sent message type=method_call sender=n/a destination=org.freedesktop.systemd1 object=/org/freedesktop/systemd1/unit/ntp_2eservice interface=org.freedesktop.DBus.Properties member=GetAll cookie=1 reply_cookie=0 error=n/a
[  100.705891] systemd[1]: Got message type=method_call sender=n/a destination=org.freedesktop.systemd1 object=/org/freedesktop/systemd1/unit/ntp_2eservice interface=org.freedesktop.DBus.Properties member=GetAll cookie=1 reply_cookie=0 error=n/a
[  100.705917] systemd[1]: ntp.service: Failed to load configuration: No such file or directory
[  100.706081] systemd[1]: Sent message type=method_return sender=n/a destination=n/a object=n/a interface=n/a member=n/a cookie=1 reply_cookie=1 error=n/a
[  100.706085] systemd[1]: ntp.service: Collecting.
[  100.706091] systemd[1]: Sent message type=signal sender=n/a destination=n/a object=/org/freedesktop/systemd1 interface=org.freedesktop.systemd1.Manager member=UnitNew cookie=2 reply_cookie=0 error=n/a
[  100.706096] systemd[1]: Sent message type=signal sender=n/a destination=n/a object=/org/freedesktop/systemd1 interface=org.freedesktop.systemd1.Manager member=UnitRemoved cookie=3 reply_cookie=0 error=n/a
[  100.706097] systemctl[945]: Got message type=method_return sender=n/a destination=n/a object=n/a interface=n/a member=n/a cookie=1 reply_cookie=1 error=n/a
[  100.706272] systemd[1]: Got disconnect on private connection.
[  100.707508] systemd[1]: Accepted new private connection.
[  100.707532] systemctl[946]: Sent message type=method_call sender=n/a destination=org.freedesktop.systemd1 object=/org/freedesktop/systemd1 interface=org.freedesktop.DBus.Properties member=Get cookie=1 reply_cookie=0 error=n/a
[  100.707543] systemd[1]: Got message type=method_call sender=n/a destination=org.freedesktop.systemd1 object=/org/freedesktop/systemd1 interface=org.freedesktop.DBus.Properties member=Get cookie=1 reply_cookie=0 error=n/a
[  100.707555] systemd[1]: Sent message type=method_return sender=n/a destination=n/a object=n/a interface=n/a member=n/a cookie=1 reply_cookie=1 error=n/a
[  100.707565] systemctl[946]: Got message type=method_return sender=n/a destination=n/a object=n/a interface=n/a member=n/a cookie=1 reply_cookie=1 error=n/a
[  100.707597] systemd[1]: Got disconnect on private connection.
[  100.708251] systemctl[947]: Looking for unit files in (higher priority first):
[  100.708253] systemctl[947]:  /etc/systemd/system
[  100.708254] systemctl[947]:  /run/systemd/system
[  100.708255] systemctl[947]:  /usr/local/lib/systemd/system
[  100.708256] systemctl[947]:  /lib/systemd/system
[  100.708257] systemctl[947]:  /usr/lib/systemd/system
[  100.708261] systemctl[947]: Looking for SysV init scripts in:
[  100.708262] systemctl[947]:  /etc/init.d
[  100.708263] systemctl[947]: Looking for SysV rcN.d links in:
[  100.708264] systemctl[947]:  /etc
[  100.708679] systemd[1]: Accepted new private connection.
[  100.708708] systemctl[947]: Sent message type=method_call sender=n/a destination=org.freedesktop.systemd1 object=/org/freedesktop/systemd1 interface=org.freedesktop.systemd1.Manager member=GetUnitFileState cookie=1 reply_cookie=0 error=n/a
[  100.708716] systemd[1]: Got message type=method_call sender=n/a destination=org.freedesktop.systemd1 object=/org/freedesktop/systemd1 interface=org.freedesktop.systemd1.Manager member=GetUnitFileState cookie=1 reply_cookie=0 error=n/a
[  100.708734] systemd[1]: Looking for unit files in (higher priority first):
[  100.708736] systemd[1]:  /etc/systemd/system
[  100.708737] systemd[1]:  /run/systemd/system
[  100.708737] systemd[1]:  /usr/local/lib/systemd/system
[  100.708738] systemd[1]:  /lib/systemd/system
[  100.708739] systemd[1]:  /usr/lib/systemd/system
[  100.708742] systemd[1]: Looking for SysV init scripts in:
[  100.708743] systemd[1]:  /etc/init.d
[  100.708745] systemd[1]: Looking for SysV rcN.d links in:
[  100.708745] systemd[1]:  /etc
[  100.708758] systemd[1]: Sent message type=error sender=n/a destination=n/a object=n/a interface=n/a member=n/a cookie=1 reply_cookie=1 error=No such file or directory
[  100.708761] systemd[1]: Failed to process message [type=method_call sender=n/a path=/org/freedesktop/systemd1 interface=org.freedesktop.systemd1.Manager member=GetUnitFileState signature=s]: No such file or directory
[  100.708775] systemctl[947]: Got message type=error sender=n/a destination=n/a object=n/a interface=n/a member=n/a cookie=1 reply_cookie=1 error=No such file or directory
[  100.708780] systemctl[947]: Failed to get unit file state for ntp.service: No such file or directory
[  100.708798] systemd[1]: Got disconnect on private connection.
[  100.709062] systemd[1]: Received SIGRTMIN+21 from PID 256 (plymouthd).
[  100.709064] systemd[1]: Disabling showing of status.
[  100.709281] systemd[1]: Received SIGCHLD from PID 894 (lockfile-touch).
[  100.709292] systemd[1]: Child 890 (lockfile-remove) died (code=exited, status=0/SUCCESS)
[  100.709309] systemd[1]: networking.service: Child 890 belongs to networking.service
[  100.709356] systemd[1]: Child 894 (lockfile-touch) died (code=exited, status=0/SUCCESS)
[  100.709368] systemd[1]: networking.service: Child 894 belongs to networking.service
[  100.709381] systemd[1]: networking.service: cgroup is empty
[  100.709434] systemd[1]: networking.service: Changed running -> exited
[  100.710095] systemd[1]: Accepted new private connection.
[  100.710157] systemd-cgroups-agent[948]: Sent message type=signal sender=n/a destination=n/a object=/org/freedesktop/systemd1/agent interface=org.freedesktop.systemd1.Agent member=Released cookie=1 reply_cookie=0 error=n/a
[  100.710171] systemd[1]: Got message type=signal sender=n/a destination=n/a object=/org/freedesktop/systemd1/agent interface=org.freedesktop.systemd1.Agent member=Released cookie=1 reply_cookie=0 error=n/a
[  100.710261] systemd[1]: Got disconnect on private connection.
[  100.733791] systemd[1]: Received SIGCHLD from PID 740 (plymouth).
[  100.733811] systemd[1]: Child 740 (plymouth) died (code=exited, status=0/SUCCESS)
[  100.733838] systemd[1]: emergency.service: Child 740 belongs to emergency.service
[  100.733843] systemd[1]: emergency.service: Control process exited, code=exited status=0
[  100.733924] systemd[1]: emergency.service: Running next control command for state start-pre.
[  100.733965] systemd[1]: emergency.service: About to execute: /bin/echo -e 'Welcome to emergency mode! After logging in, type "journalctl -xb" to view\nsystem logs, "systemctl reboot" to reboot, "systemctl default" or ^D to\ntry again to boot into default mode.'
[  100.734057] systemd[1]: emergency.service: Forked /bin/echo as 950
[  100.734440] systemd[950]: emergency.service: Executing: /bin/echo -e 'Welcome to emergency mode! After logging in, type "journalctl -xb" to view\nsystem logs, "systemctl reboot" to reboot, "systemctl default" or ^D to\ntry again to boot into default mode.'
[  100.734848] systemd[1]: Accepted new private connection.
[  100.734893] systemd[1]: Received SIGCHLD from PID 950 (echo).
[  100.734901] systemd[1]: Child 950 (echo) died (code=exited, status=0/SUCCESS)
[  100.734913] systemd[1]: emergency.service: Child 950 belongs to emergency.service
[  100.734915] systemd[1]: emergency.service: Control process exited, code=exited status=0
[  100.734934] systemd[1]: emergency.service: Got final SIGCHLD for state start-pre.
[  100.734952] systemd[1]: emergency.service: About to execute: /bin/sh -c '/sbin/sulogin; /bin/systemctl --job-mode=fail --no-block default'
[  100.735012] systemd[1]: emergency.service: Forked /bin/sh as 952
[  100.735065] systemd[1]: emergency.service: Changed start-pre -> running
[  100.735182] systemd-cgroups-agent[949]: Sent message type=signal sender=n/a destination=n/a object=/org/freedesktop/systemd1/agent interface=org.freedesktop.systemd1.Agent member=Released cookie=1 reply_cookie=0 error=n/a
[  100.735307] systemd[952]: emergency.service: Executing: /bin/sh -c '/sbin/sulogin; /bin/systemctl --job-mode=fail --no-block default'
[  100.735694] systemd[1]: Accepted new private connection.
[  100.735734] systemd[1]: Got disconnect on private connection.
[  100.735734] systemd-cgroups-agent[951]: Sent message type=signal sender=n/a destination=n/a object=/org/freedesktop/systemd1/agent interface=org.freedesktop.systemd1.Agent member=Released cookie=1 reply_cookie=0 error=n/a
[  100.735933] systemd[1]: Got message type=signal sender=n/a destination=n/a object=/org/freedesktop/systemd1/agent interface=org.freedesktop.systemd1.Agent member=Released cookie=1 reply_cookie=0 error=n/a
[  100.735973] systemd[1]: Received SIGCHLD from PID 256 (plymouthd).
[  100.735990] systemd[1]: Child 256 (plymouthd) died (code=exited, status=0/SUCCESS)
[  100.736018] systemd[1]: Got disconnect on private connection.
[  100.736998] systemd[1]: Accepted new private connection.
[  100.737018] systemd-cgroups-agent[954]: Sent message type=signal sender=n/a destination=n/a object=/org/freedesktop/systemd1/agent interface=org.freedesktop.systemd1.Agent member=Released cookie=1 reply_cookie=0 error=n/a
[  100.737027] systemd[1]: Got message type=signal sender=n/a destination=n/a object=/org/freedesktop/systemd1/agent interface=org.freedesktop.systemd1.Agent member=Released cookie=1 reply_cookie=0 error=n/a
[  100.737079] systemd[1]: Got disconnect on private connection.
[  103.609741] systemd[1]: systemd-udevd.service: Got notification message from PID 487 (WATCHDOG=1)
OK this is silly but I found the solution the error had to do with an /etc/fstab entry for an USB drive:
/dev/disk/by-label/SeqData1 /mnt/SeqData1 nosuid,nodev,nobootwait,nofail,noauto,x-gvfs-show 0 0
I had to comment this one out and systemd booted fine. Why this entry for a USB drive was there in the first place I'm not sure. I tried first using nofail and nopootwait but that didn't help. Still confused about all this but the problem is solved.
