18
After installation of CLAMAV and try to scan I see this error. How do I solve this?
$ clamscan scan
LibClamAV Error: cli_loaddbdir(): No supported database files found in /var/lib/clamav
ERROR: Can't open file or directory
----------- SCAN SUMMARY -----------
Known viruses: 0
Engine version: 0.98.7
Scanned directories: 0
Scanned files: 0
Infected files: 0
Data scanned: 0.00 MB
Data read: 0.00 MB (ratio 0.00:1)
Time: 0.003 sec (0 m 0 s)
Melebius
  • 11,750
8 Answers8
19
Steps 1-3 below include commands run in a terminal. Please read carefully so that you understand what you are doing.
  1. Remove potentially bad AV installations:
    sudo apt-get remove clamav
    sudo apt-get remove clamtk
    sudo apt-get remove freshclam
    sudo apt-get clean
    sudo apt-get autoremove
  2. Reinstall AV:
    sudo apt-get install clamav        #Terminal Version
    sudo apt-get install clamtk         #GUI version
  3. Update AV Database:
    sudo freshclam               #takes ~30 minutes to download definitions
  4. Configure AV & Scan:
    This example uses clamtk only
    clamtk                      #Opens GUI
    toggle all options under Settings tab:
    Network
    • toggle proxy and type http://127.0.0.1
    • toggle / reselect **No Proxy **(to gray out what you entered above)
    Update Assistant
    • toggle manual update option and click apply and back
    • toggle automatic update option and click apply and back
    You should now see updated definition count
    Scan a Directory
    • select directory you want scanned. For system scan I toggled the entire system (not just /root or /usr)
    • Click scan and a progress box will appear.
Final Note: typing the phrase --help (without quotations) following command gives some hints. With APT commands you can pass the option -y to say yes to installing all dependencies for the requested package.
This is what I had to do to get clam working, perhaps a glitch for both clamtk and clamav (problem with both). Hope this helps someone else!!!
Zanna
  • 72,312
The error message tells the tale: LibClamAV Error: cli_loaddbdir(): No supported database files found in /var/lib/clamav and Known viruses: 0
You need
clamav-freshclam - anti-virus utility for Unix - virus database update utility
Also ensure that user running the scan has read access to /var/lib/clamav.
waltinator
  • 37,856
cuongpv@anonymouse /home> clamscan --infected --remove --recursive /home
Known viruses: 0
Engine version: 0.100.2
Scanned files: 0
Infected files: 0
No supported database files found in /var/lib/clamav it mean the database still not avaible to use. Almost of this case is you have just installed clamav. So you need to wait util the database update completed.
You can check with: ps aux | grep clam The result should be
clamav   29675  3.5  0.3 154276 27632 ?        Ss   11:36   0:08 /usr/bin/freshclam -d --foreground=true
Waiting for util the database update complete.
Hope useful for you.
There is a time limit for downloading database, in my version it was 30 seconds. Initial file to download is ~60MB.
And now, most peculiar thing: if your connection is slow and you don't get this file within 30s, connection is dropped and it start download it again, from the beginning!
And will continue to do so over and over until it downloads this file in this time window.
To make sure if it is the case, run (kill it before if it's running):
sudo freshclam -v # verbose mode
Solution: Increase ConnectTimeout and ReceiveTimeout in:
sudo gedit /etc/clamav/freshclam.conf
source: https://forum.directadmin.com/threads/how-to-pass-60-sec-time-limit.60045/
Sebastian
  • 121
Install clamdscan by running:
sudo apt-get install clamdscan
Kaz Wolfe
  • 34,680
Tono
After a new installation usually the clamav database and signatures keep downloading without informing the users and without any notifications and users have to wait till all the signatures get updated. That's the real problem.
Checked for the update by using command $ sudo freshclam when the error messages are like below:
ERROR: /var/log/clamav/freshclam.log is locked by another process
ERROR: Problem with internal logger (UpdateLogFile = /var/log/clamav/freshclam.log).
Once database get updated Try at first only
$ clamscan
by default it will check home directory.
then use however you like to, like used earlier command...
$ clamscan --infected --remove --recursive /home
I had to manually create and set the directory /var/lib/clamav to 777, then run freshclam. This downloaded all the signatures and updated clamav, and all seems well now.
RedLee
me too, on two computers clam runs without any hassle or problems. one pc causes always problems with ... updates,.. yes, why is it always the problem with updating.!
so i manually have set the virus def database to /home/{my userlogin}/.clamtk/db/
I have set it in my home folder, because it seemed to cause problems in other locations .. thus. everytime i need to update it (once a week) i delete everything in that folder, then i run within that folder;
freshclam --show-progress
in a terminal to get the updates. otherwise it will not update , clamtk does not work, no updates are possible to download from there. BUT not within clamtk, but there it DOES show how many virri defs i just downloaded with
further CLAMTK does run with the virusscans, and shows progress, and detects malware..
