62
How do I install the latest node inside a docker ubuntu 15.10 container? apt-get install nodejs installs version 0.1 and no npm
Thanks
Tomasz
  • 1,343
11 Answers11
62
OK got it,
# update
apt-get update
# install curl
apt-get install curl
# get install script and pass it to execute:
curl -sL https://deb.nodesource.com/setup_4.x | bash
# and install node
# confirm that it was successful
node -v
# npm installs automatically
npm -v
Use curl -sL https://deb.nodesource.com/setup_5.x | bash for node 5.x
Replace 5 by your desired node version e.g. 8, 12, etc.
Nam G VU
  • 2,378
Tomasz
  • 1,343
42
Updated solution as of Jan 2019:
FROM ubuntu:latest
USER root
WORKDIR /home/app
COPY ./package.json /home/app/package.json
RUN apt-get update
RUN apt-get -y install curl gnupg
RUN curl -sL https://deb.nodesource.com/setup_11.x  | bash -
RUN apt-get -y install nodejs
RUN npm install
Dan
  • 521
15
This is how I have been installing nodeJS into a container. In my case, I am using an nginx base image.
Use the following command
    apt-get update -yq \
    && apt-get install curl gnupg -yq \
    && curl -sL https://deb.nodesource.com/setup_8.x | bash \
    && apt-get install nodejs -yq
GNUPG is needed by the nodeJS installer. Without it, you will get the following error message;
[91mE: gnupg, gnupg2 and gnupg1 do not seem to be installed, but one of them is required for this operation
abu_bua
  • 11,313
Sage
  • 251
10
You can add a single line to your Dockerfile.
FROM node:8.2
There is a list of supported tag names here: https://hub.docker.com/_/node/
posit labs
  • 201
Here is my Dockerfile to do this:
FROM ubuntu:20.04
RUN apt update
# We directly answer the questions asked using the printf statement
RUN printf 'y\n1\n\1n' | apt install nodejs
RUN apt install -y npm
Here we do our docker build:
docker build -t mynpm .
Here is the version check to verify its success:
docker run -it mynpm npm -v
The output I get as a result is: 6.14.4
Daan
  • 131
From Node official docker image:
Docker
Dockerfile:
# Install node and npm:
ENV NODE_VERSION 14.18.2
RUN ARCH= && dpkgArch="$(dpkg --print-architecture)"
&& case "${dpkgArch##-}" in
amd64) ARCH='x64';;
ppc64el) ARCH='ppc64le';;
s390x) ARCH='s390x';;
arm64) ARCH='arm64';;
armhf) ARCH='armv7l';;
i386) ARCH='x86';; \
) echo "unsupported architecture"; exit 1 ;;
esac
&& curl -fsSLO --compressed "https://nodejs.org/dist/v$NODE_VERSION/node-v$NODE_VERSION-linux-$ARCH.tar.xz"
&& tar -xJf "node-v$NODE_VERSION-linux-$ARCH.tar.xz" -C /usr/local --strip-components=1 --no-same-owner
&& rm "node-v$NODE_VERSION-linux-$ARCH.tar.xz"
&& ln -s /usr/local/bin/node /usr/local/bin/nodejs \
smoke tests
&& node --version
&& npm --version
meles
  • 31
installing nodejs v8 with ubuntu 16.04 base image:
FROM ubuntu:16.04
WORKDIR /app
RUN echo "LC_ALL=en_US.UTF-8" >> /etc/environment
RUN echo "LANG=en_US.UTF-8" >> /etc/environment
RUN echo "NODE_ENV=development" >> /etc/environment
RUN more "/etc/environment"
#RUN locale-gen en_US en_US.UTF-8
#RUN dpkg-reconfigure locales
RUN apt-get update
#RUN apt-get upgrade -y
#RUN apt-get dist-upgrade -y
RUN apt-get install curl htop git zip nano ncdu build-essential chrpath libssl-dev libxft-dev pkg-config glib2.0-dev libexpat1-dev gobject-introspection python-gi-dev apt-transport-https libgirepository1.0-dev libtiff5-dev libjpeg-turbo8-dev libgsf-1-dev fail2ban nginx -y
# Install Node.js
RUN curl -sL https://deb.nodesource.com/setup_8.x | bash
RUN apt-get install --yes nodejs
RUN node -v
RUN npm -v
RUN npm i -g nodemon
RUN nodemon -v
# Cleanup
RUN apt-get update && apt-get upgrade -y && apt-get autoremove -y
I also installed some extra dependencies I need so you can clean up this code for your needs. But it installs nodejs & npm & nodemon.
You can combine two docker images:
FROM node:16 AS node_base
FROM ubuntu:bionic
COPY --from=node_base / /
See: https://stackoverflow.com/a/61054246/10030693
Gilboot
  • 121
I am using following Dockerfile to setup node version 8.10.0.
Here I have used NVM (Node Version Manager ), so we can choose which node version should be installed on that container. Please use absolute path of npm when installing node modules (eg: /root/.nvm/versions/node/v${NODE_VERSION}/bin/npm install leasot@latest -g)
   FROM ubuntu:18.04
   ENV NODE_VERSION=8.10.0
   RUN apt-get update && \
       apt-get install wget curl ca-certificates rsync -y
   RUN wget -qO- https://raw.githubusercontent.com/creationix/nvm/v0.33.2/install.sh | bash
   ENV NVM_DIR=/root/.nvm
   RUN . "$NVM_DIR/nvm.sh" && nvm install ${NODE_VERSION}
   RUN . "$NVM_DIR/nvm.sh" &&  nvm use v${NODE_VERSION}
   RUN . "$NVM_DIR/nvm.sh" && nvm alias default v${NODE_VERSION}
   RUN cp /root/.nvm/versions/node/v${NODE_VERSION}/bin/node /usr/bin/
   RUN cp /root/.nvm/versions/node/v${NODE_VERSION}/bin/npm /usr/bin/
   RUN /root/.nvm/versions/node/v${NODE_VERSION}/bin/npm install  leasot@latest -g
Note: This is a cropped Dockerfile.
Sijo M Cyril
  • 111
I tried something like this, which i usually do, download binary and put it in classpath.
FROM ubuntu:22.04
Copy files
COPY ./ /app
#Change Workdir WORKDIR /app
RUN apt-get update && apt-get install -y wget build-essential && apt-get clean
RUN mkdir -p /node
Install Node dependencies.
RUN wget https://nodejs.org/dist/v20.13.1/node-v20.13.1-linux-x64.tar.xz
&& mkdir -p /node && tar -xf node-v20.13.1-linux-x64.tar.xz -C /node
&& chmod +x -R /node/node-v20.13.1-linux-x64
Setup Path
ENV PATH="/node/node-v20.13.1-linux-x64/bin:${PATH}"
RUN npm install
#Start App ENTRYPOINT [ "node", "/app/index.js" ]
-1
# Base OS
FROM ubuntu:latest
# Node installation
RUN apt -y install nodejs npm
# Node package manager
RUN npm install -g n
# Upgrade to latest stable version
RUN n stable
momo2047
  • 233
