I have installed Ubuntu 14.04 on hp stream 11. Wireless device is not being detected.
Windows detects it as Broadcom BCM43142 802.11 bgn.
Is it possible to get the drivers for Ubuntu and install manually?
EDIT: I downloaded packages manually, now getting another error
$ sudo dpkg -i dkms_2.2.0.3-1.1ubuntu5.14.04.5_all.deb
(Reading database ... 164809 files and directories currently installed.)
Preparing to unpack dkms_2.2.0.3-1.1ubuntu5.14.04.5_all.deb ...
Unpacking dkms (2.2.0.3-1.1ubuntu5.14.04.5) over (2.2.0.3-1.1ubuntu5.14.04.5) ...
Setting up dkms (2.2.0.3-1.1ubuntu5.14.04.5) ...
Processing triggers for man-db (2.6.7.1-1ubuntu1) ...
compX@compX-HP-Stream-Notebook-PC-11:~$ sudo dpkg -i bcmwl-kernel-source_6.30.223.141+bdcom-0ubuntu2_amd64.deb
Preparing to unpack bcmwl-kernel-source_6.30.223.141+bdcom-0ubuntu2_amd64.deb ...
Removing all DKMS Modules
Done.
Unpacking bcmwl-kernel-source (6.30.223.141+bdcom-0ubuntu2) over (6.30.223.141+bdcom-0ubuntu2) ...
Setting up bcmwl-kernel-source (6.30.223.141+bdcom-0ubuntu2) ...
Loading new bcmwl-6.30.223.141+bdcom DKMS files...
Building only for 3.19.0-25-generic
Building for architecture x86_64
Building initial module for 3.19.0-25-generic
ERROR (dkms apport): kernel package linux-headers-3.19.0-25-generic is not supported
Error! Bad return status for module build on kernel: 3.19.0-25-generic (x86_64)
Consult /var/lib/dkms/bcmwl/6.30.223.141+bdcom/build/make.log for more information.
modprobe: FATAL: Module wl not found.
update-initramfs: deferring update (trigger activated)
Processing triggers for initramfs-tools (0.103ubuntu4.2) ...
update-initramfs: Generating /boot/initrd.img-3.19.0-25-generic
compX@compX-HP-Stream-Notebook-PC-11:~$ more /var/lib/dkms/bcmwl/6.30.223.141+bdcom/build/make.log
DKMS make.log for bcmwl-6.30.223.141+bdcom for kernel 3.19.0-25-generic (x86_64)
Thu Jan 14 21:21:06 GMT 2016
make: Entering directory ```/usr/src/linux-headers-3.19.0-25-generic'
CFG80211 API is prefered for this kernel version
Using CFG80211 API
LD /var/lib/dkms/bcmwl/6.30.223.141+bdcom/build/built-in.o
CC [M] /var/lib/dkms/bcmwl/6.30.223.141+bdcom/build/src/shared/linux_osl.o
CC [M] /var/lib/dkms/bcmwl/6.30.223.141+bdcom/build/src/wl/sys/wl_linux.o
/var/lib/dkms/bcmwl/6.30.223.141+bdcom/build/src/wl/sys/wl_linux.c: In function ‘wl_alloc_linux_if’:
/var/lib/dkms/bcmwl/6.30.223.141+bdcom/build/src/wl/sys/wl_linux.c:1354:64: error: macro "alloc_netdev" requires 4 arguments, but only 3 given
dev = alloc_netdev(sizeof(priv_link_t), intf_name, ether_setup);
/var/lib/dkms/bcmwl/6.30.223.141+bdcom/build/src/wl/sys/wl_linux.c:1354:8: error: ‘alloc_netdev’ undeclared (first use in this function)
/var/lib/dkms/bcmwl/6.30.223.141+bdcom/build/src/wl/sys/wl_linux.c:1354:8: note: each undeclared identifier is reported only once for each funct
ion it appears in
make[1]: *** [/var/lib/dkms/bcmwl/6.30.223.141+bdcom/build/src/wl/sys/wl_linux.o] Error 1
make: *** [_module_/var/lib/dkms/bcmwl/6.30.223.141+bdcom/build] Error 2
make: Leaving directory `/usr/src/linux-headers-3.19.0-25-generic'
EDIT2:More info is provided about the installation and network. Cannot get it to work :(
$ sudo lshw -C network
*-network
description: Network controller
product: BCM43142 802.11b/g/n
vendor: Broadcom Corporation
physical id: 0
bus info: pci@0000:01:00.0
version: 01
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress bus_master cap_list
configuration: driver=bcma-pci-bridge latency=0
resources: irq:16 memory:90400000-90407fff
compXXX@compXXX-HP-Stream-Notebook-PC-11:~$ uname -a
Linux compXXX-HP-Stream-Notebook-PC-11 3.19.0-25-generic #26~14.04.1-Ubuntu SMP Fri Jul 24 21:16:20 UTC 2015 x86_64 x86_64 x86_64 GNU/Linux
compXXX@compXXX-HP-Stream-Notebook-PC-11:~$ uname -r
3.19.0-25-generic
