I'm on a Lenovo ThinkPad Yoga s1 running Ubuntu 15.10.
Just yesterday I installed a second SSD in my laptop. I removed the main drive with Ubuntu, installed Windows 10 onto the second drive, then reinserted the main drive and ran sudo update-grub. When I rebooted, I saw both Ubuntu and Windows 10, but now when I boot into Windows I'm stuck on a purple screen.
What's weird is that if I load BIOS and select which drive to boot from, I can access Windows through grub just fine. But when I change the boot order to prioritize either the main or secondary drive I get the same issue (related note, should Windows Boot Loader be listed very high up in the boot order?).
I've downloaded and used the boot-repair utility, and I've also ran some commands within the grub console with no luck.
For reference, here is the boot-repair pastebin: http://paste.ubuntu.com/14473911/
One solution I've found recommends booting into Windows and running bootrec/fixmbr and bootrec/fixboot, but it seems like these commands will replace grub, and I don't want to lose access to Ubuntu.
Any ideas on what I could do to be able to load Windows from grub without selecting the right disk from BIOS?
Quick update: If I load BIOS at all and then boot to Windows it works fine. Otherwise if I just turn on my computer and select Windows, I get the purple screen.
Found a solution:
The fix I found was to disable quick-booting in windows. It's listed right in the pastebin that windows 10 was in an unsafe state and could not be booted, and to disable quick-boot.
Create a new script file in /etc/grub.d, called 12_custom, with this code:
#!/bin/sh -e
echo "Adding Windows 10 to GRUB 2 menu"
cat << EOF
menuentry "Windows 10" {
     set root=(hd1,1)
     chainloader (hd1,1)+1
EOF
The hd1 corresponds to disk 2, and /dev/sdb, but hd0 is disk 1, or /dev/sda. You may need root access to create the file. Make it executable with chmod +x 12_custom. Update your GRUB with sudo update-grub. Reboot to see if you get to choose between Ubuntu and Windows.
theodorn
  • 794
