I am very fascinated with the professional help here on AskUbuntu. And I need your help again. I installed Ubuntu just two days ago and spent all this time setting it up. Now the question is about the Photoshop.
I followed this: https://askubuntu.com/a/530127/491656
sudo add-apt-repository ppa:ubuntu-wine/ppa
sudo apt-get update && sudo apt-get upgrade
sudo apt-get install wine1.7 winetricks
Everything was fine, but after the last one I got:
winetricks atmlib gdiplus msxml3 msxml6 vcrun2005 vcrun2005sp1 vcrun2008 ie6 fontsmooth-rgb gecko
I installed the Photoshop, but...I decided to delete all these and Photoshop, because I don't wont to use it in Linux. It feels like I miss Windows, but I don't. I'm looking forward to delete all files and dependencies installed so nothing left in Ubuntu. Could you please, help me to clarify what should I write in terminal?
I have Ubuntu 14.04 LTS 64b
Before following CiberSheep instructions, you can delete Photoshop with the Wine Uninstaller. Run, in a terminal:
wine uninstaller
Find Photoshop and remove it.
After doing what CiberSheep said, run sudo apt-get autoremove to remove dependencies.
Eduardo Cola
  • 5,876
  • 20
  • 33
You can type this in the terminal.
sudo apt-get purge wine
That would be enough to uninstall and purge it. But it is important that you understand what you are doing ;) so at the beginning take some time to look for the commands you are going to type in the terminal.
You can take a look here.
