Kupfer is a keyboard-oriented program, so it's strange that it suddenly won't respond to any key commands. Once I summon it, the window pops up, but nothing I type has any effect.
Start kupfer using the kupfer --debug command and try again: that won't make it work but will at least give you a hint on why it doesn't work.
It is likely that some plugin causes an error preventing kupfer from working.
I had this issue with the Empathy plugin and it has bothered me for hours.
- 196
This happened to me when I deleted a folder that was in the catalog of folders for Kupfer to monitor. I had to do a complete uninstall and reinstall via synaptic to resume normal function.
- 11
- 1
Does your window manager have "auto-raise" (automatic focusing of windows as the cursor moves over them) enabled? If so, then unless your mouse is already in the area on the screen where Kupfer shows itself, then focus will immediately revert to any window that the mouse is currently over.
- 113
