I keep getting the following message and am new to Ubuntu. Not sure how to increase the space in boot volume from other partition.
The volume "boot" has only 2.8 mb disk space remaining
it also suggests "you can free up disk space by removing unused programs or files, or by moving files to another disk or partition"
can someone help?
Thanks
Seems duplicated with : What is the safest way to clean up /boot partition?
Get the list of kernel images (this command will show installed kernels except the currently running one) :
sudo dpkg --list 'linux-image*'|awk '{ if ($1=="ii") print $2}'|grep -v `uname -r`
Note the two newest versions in the list to keep it. Delete all files in /boot for kernels except the current and two newest kernel images. Example:
sudo rm -rf /boot/*-3.13.0-{23,45,49}-*.
Then, clean up what's making apt grumpy about a partial install :
sudo apt-get -f install
sudo apt-get autoremove
If you run into an error that includes a line like "Internal Error: Could not find image (/boot/vmlinuz-3.2.0-56-generic)", then run the command sudo apt-get purge linux-image-3.2.0-56-generic (with your appropriate version).
EvanK wrote a good python script here to automate this cleaning : https://github.com/EvanK/ubuntu-purge-kernels
