So I want to be able to SSH into my home desktop. I set up port forwarding on my router, and was able to ssh into my machine
ssh alex@2601:647:4802:b000:e938:d8b5:6111:e0fb
When I restart the machine, the IP address changes, so I'd like to set up Dynamic DNS. I have a domain name on google domains, which offers Dynamic DNS for free. This tutorial is supposed to help you set it up.
I follow the steps, install ddclient, and totally overwrite ddclient.conf with what the article recommends:
protocol=dyndns2
use=web
server=domains.google.com
ssl=yes
login=generated_username
password=generated_password
your_resource.your_domain.tld
I test ddclient with the command
sudo ddclient -daemon=0 -debug -verbose -noquiet
and I get
SUCCESS:  subdomain.mydomain.org: skipped: IP address was already set to 50.184.58.242.
which is curiously an ipv4 address, whereas I thought I had an ipv6 address. Anyhow. I've waited a little while and it doesn't work. I get
ssh: connect to host subdomain.mydomain.org port 22: Connection refused
or it hangs. Not sure where to go from here. I don't have a particularly strong mental model of how any of this works, I just want to be able to
ssh alex@subdomain.mydomain.org
whenever I please, and allow for the computer to be turned off every once in a while (meaning ip address changes).
Turns out you need quotes around your password, i.e.
password='generated_password'
which the google article doesn't allude to.
