I'm experiencing some crazy issues regarding my internet speed using Ubuntu 15.04. I can't get anything greater than 10Mbps down,but I'm achieve 30 Mbps up.
My laptop doesn't have an Ethernet port, but uses a Intel 7260 Dual Band wireless card. I figured that this card was the source of all my problems. Usually they are 4 sources of internet issues.
ISP level, Router Level, Driver Level, Hardware Level.
But I haven't been able to narrow it down. My ISP is fios and every other device in the house performance is great. It is not the router, as once again other wireless devices are having no issues.
So I'm thinking it must be the driver or hardware, the wireless card is prone to issues in Ubuntu and Windows. However I had a Sony WLan adapter and I figured I would use that until I replace the card. Well the performance still is the same, around 10 Mbps down and 30 Mbps up.
I have never seen anything like this.
Also in Connection Information the speed says 130 Mbps, but the actually throughput still stays under 10Mbps.
So this answer help me.
https://askubuntu.com/a/638554/491662
Turn off bluetooth (use rfkill or turn off in Bios) Turn OFF 802.11n mode (in /etc/modprobe.d/iwlwifi.conf add options iwlwifi 11n_disable=1) Turn ON link aggregation (in /etc/modprobe.d/iwlwifi.conf add options iwlwifi 11n_disable=8) Turn OFF watchdog (in /etc/modprobe.d/iwlwifi.conf add options iwlwifi wd_disable=1) Turn off power saving features ($ sudo iw wlan0 set power_save off) Set regulatory domain ($ sudo iw reg set )
All my research has me to believe that bluetooth is a major culprit. For instance I realize this problems didn't start until I started using a pair of bluetooth headphones with my laptop. Also If I follow those instructions but skipped turning of bluetooth, the performance will increase until a bluetooth device is connected.
I still don't know why bluetooth would only interfere with the download speed and not the upload speed.
As suggested , bluetooth isn't the main culprit
I have made another change which as dramatically improved performance. The router supplied by Fios has two internal wireless access points. One operates at 2.4 GHz and is (b,g,n capable) while the other operates at 5 GHz (n,ac capable). They were set to the same SSID. Once I changed the ID my connection to the routers says at around 130-200 Mbps.
There still might be another problem, on other ac capable routers I get around 500 Mbps. But my actual bandwidth from FIOS is no where near that, and I'm not doing any local networking stuff some I'm fine with this improvement.
