I have run into similar problems like you (Lubuntu 16.04).
This comes due to drivers/modules binding the devices to them before pci-stub is able to do this.
You have at least two options in here:
The first and easiest one would be to blacklist the modules that claim the device.
Type in lspci -knn | grep VGA -A 5 to see all your VGA pci devices and their device-number and their kernel modules.
01:00.0 VGA compatible controller [0300]: NVIDIA Corporation Device [10de:128b] (rev a1)
Subsystem: Micro-Star International Co., Ltd. [MSI] Device [1462:8c93]
Kernel driver in use: nouveau
Kernel modules: nvidiafb, nouveau
01:00.1 Audio device [0403]: NVIDIA Corporation GK208 HDMI/DP Audio Controller [10de:0e0f] (rev a1)
Subsystem: Micro-Star International Co., Ltd. [MSI] GK208 HDMI/DP Audio Controller [1462:8c93]
02:00.0 VGA compatible controller [0300]: NVIDIA Corporation GM204 [GeForce GTX 970] [10de:13c2] (rev a1)
Subsystem: ZOTAC International (MCO) Ltd. GM204 [GeForce GTX 970] [19da:1366]
02:00.1 Audio device [0403]: NVIDIA Corporation GM204 High Definition Audio Controller [10de:0fbb] (rev a1)
Subsystem: ZOTAC International (MCO) Ltd. GM204 High Definition Audio Controller [19da:1366]
Now you need to check which driver is in use. For example nouveau grabbed my VGA-device 02:00.0 which i want to use for my VM, so I blacklist that one in:
sudo nano /etc/modprobe.d/blacklist.conf
blacklist nouveau
and your are done.
In my case this would cause a problem since I have two nVidia VGA's installed (01:00.0 and 02:00.0) both running with the same driver. In my case I do not blacklist the driver.
I do manually unbind nouveau from my 02:00.0 VGA card, since i wanted to use
that card for my VM-guest and the 01:00.0 VGA for my Linux host.
Thanks to this guide i found out how to do so: https://lwn.net/Articles/143397/
Type in sudo tree /sys/bus/pci/drivers/nouveau. Exchange nouveau with whatever module grabbed your device.
You should recieve a list like this:
├── 0000:01:00.0 -> ../../../../devices/pci0000:00/0000:00:03.0/0000:01:00.0
├── 0000:02:00.0 -> ../../../../devices/pci0000:00/0000:00:05.0/0000:02:00.0
├── bind
├── module -> ../../../../module/drm
├── new_id
├── remove_id
├── uevent
└── unbind
We see that driver nouveau has to devices binding to it: 0000:01:00.0 and 0000:02:00.0
To unbind and bind my graphic-card I first need to turn off lightdm.service. Therefor I open the console outside of the desktop environment with CTRL+ALT+F2 for example.
Login as root and type systemctl stop lightdm.service
Now I can unbind the module from the graphics-card:
echo -n "0000:02:00.0" > /sys/bus/pci/drivers/nouveau/unbind
and bind it to whatever module I want (pci-stub or vfio-pci). I used vfio-pci.
echo -n "0000:02:00.0" > /sys/bus/pci/drivers/vfio-pci/bind
After that, you can start your desktopmanager again:
systemctl start lightdm.service
If everything worked you should find your device binded to the module you specified by looking up with lspci -knn | grep VGA -A 5 again.
Kernel driver in use: vfio-pci
Unfortunately this workaround loses effect after reboot. Yet i did not find out on how to make it persistent. Maybe anybody else can give me a hint. Something like a startscript would be possible, i guess. But it would be better beeing able to bind the device to a specific module without having to unbind it first. Imagine i would like to use the nvidia driver one day. In that case unbinding from nouveau would be useless since the graphics card would be bind to the nvidia module.
