I was running 11.04 before upgrading to 11.10 recently and now I am not able to access my account. When I try to login, the console flashes up with some messages on it, then the NVidia logo pops up and then it takes me back to the login screen. I have a Latitude E6500.
I believe the issue stems from here: when using 11.04 I tried to get the cube working on Compiz against others recommendations. Eventually I hosed my CCSM settings and was not able to login to the account anymore without changing to Ubuntu Classic on the login menu. Now that Ubuntu classic is gone in 11.10 I'm only able to login through the guest account (to see a desktop at least, terminal is still fine).
I believe if I can reset my CCSM settings back to default through the terminal while logged into my main account that would fix it. Any ideas?
Don Kirkby
  • 1,489
scott
  • 91
If you're using Unity and you want to reset Unity to its default settings, want to reset the Unity Launcher icons or you've changed some Compiz settings which have messed up Ubuntu and want to reset everything, here's how to do it.
Reset Unity
If you want to reset Unity (this will only reset the Unity settings in CompizConfig Settings Manager and leave the other CCSM settings intact), open a terminal (or press ALT + F2) and enter:
unity --reset
Reset Unity Launcher icons
If you want to reset the Unity Launcher icons (dock bar on the left) to their initial state, run the following command:
unity --reset-icons
Reset Compiz
Warning: only do this if you really must and have no other option! Use both commands, or else you might not see the Unity launcher and top panel anymore! Use it at your own risk.
To reset all the Compiz settings (this includes all the plugins settings, etc.) to the default values, open a terminal (don't run it with ALT + F2! The top panel and launcher will disappear after running the first command but will show up after the second one so use a terminal) and type:
gconftool-2 --recursive-unset /apps/compiz-1
unity --reset
If something doesn't look right after this, log out and log back in.
hhlp
  • 42,872
Maybe this will help you, or someone else: If nothing else works, install ubuntu tweak.
Use Ctrl+Alt+T then enter
sudo apt-get install ubuntu-tweak
Then go to admins>>Desktop recovery>>reset
This was the only solution that worked for me.
I did this after unity --reset and re-installing unity failed, and probably everything else I read off the net.
twengg
  • 81
If you can do that in a terminal press the keys ctrl+alt+F1 at the login screen to access a terminal, there you can login with your account and reset compiz to defaults with
If compiz was the issue this will reset your configuration and plugins back to default.
Bruno Pereira
  • 74,715
You might try this:
  1. Press Ctrl+Alt+F1 from the login screen, and then log in via the terminal that comes up.
  2. cd into ~/.gconf
  3. Remove[1] apps/compiz-1/, apps/compizconfig-1/, and apps/metacity/ (and perhaps desktop/).
  4. Press Ctrl+Alt+F7 to get back to the login screen, then log in. Has this fixed the problem?
[1] Preferably by copying them into a different directory so you can restore them later if you need to.
zpletan
  • 3,443
