I'm running a dual boot Windows 10 and Ubuntu 15.10 on my HP Spectre X360. Everything worked fine until I updated Ubuntu and it asked me to restart the system. After the restart GRUB wouldn't show anymore and my computer would immediately boot into Windows.
I tried the following:
  • holding shift during boot: Nothing happens
  • Changing the boot order: Only Windows boot manager shows up so I can't change anything
  • doing a boot-repair: After running it I got this log http://paste2.org/0Cwwt45W but it didn't fix my problem.
So far I don't know what else to try.
Edit: I can hit esc, then "Boot Device Options" then "Boot from EFI file" then"EFI" then "Ubuntu" then "grubx64.efi" and boot Ubuntu that way.
Now the interesting entries in /var/log/apt/history.log are
Install:
linux-headers-4.2.0-23-generic:amd64 (4.2.0-23.28, automatic)
linux-signed-image-4.2.0-23-generic:amd64 (4.2.0-23.28, automatic)
linux-image-extra-4.2.0-23-generic:amd64 (4.2.0-23.28, automatic)
linux-headers-4.2.0-23:amd64 (4.2.0-23.28, automatic)
linux-image-4.2.0-23-generic:amd64 (4.2.0-23.28, automatic)
Upgrade:
linux-headers-generic:amd64 (4.2.0.22.24, 4.2.0.23.25)
grub-efi-amd64-bin:amd64 (2.02~beta2-29ubuntu0.2, 2.02~beta2-29ubuntu0.3)
grub-efi-amd64:amd64 (2.02~beta2-29ubuntu0.2, 2.02~beta2-29ubuntu0.3)
grub-common:amd64 (2.02~beta2-29ubuntu0.2, 2.02~beta2-29ubuntu0.3)
grub2-common:amd64 (2.02~beta2-29ubuntu0.2, 2.02~beta2-29ubuntu0.3)
linux-signed-generic:amd64 (4.2.0.22.24, 4.2.0.23.25)
grub-efi-amd64-signed:amd64 (1.55.2+2.02~beta2-29ubuntu0.2, 1.55.3+2.02~beta2-29ubuntu0.3)
linux-signed-image-generic:amd64 (4.2.0.22.24, 4.2.0.23.25)
linux-image-generic:amd64 (4.2.0.22.24, 4.2.0.23.25)
linux-generic:amd64 (4.2.0.22.24, 4.2.0.23.25)
5 Answers5
Windows 10 loves to see itself as the only installed OS on your computer, thus making you unable to boot into others. What you need to do is to set GRUB as the default boot manager in Windows through an admin Command Prompt or PowerShell.
Run this command:
bcdedit /set {bootmgr} path \EFI\ubuntu\grubx64.efi
If you use PowerShell, run this command:
bcdedit /set "{bootmgr}" path \EFI\ubuntu\grubx64.efi
Restart your computer then grub should show up after the HP logo.
Vin
You'll have to change the bootorder in your BIOS. At startup you'll have to press a button to enter it. Most often F2 or del. There you'll have to choose your ubuntu partition as first priority to boot from. This all depends on your motherboard and your bios version. Search for your motherboard if you're not able to figure out which button to press on startup.
It looks like you're machine is using UEFI. I assume that the new grub bootloader is not being recognized by the BIOS and hence it boots Windows. I observed this behaviour at a laptop which refused to boot into Linux (GRUB) unless "legacy boot" was selected.
This gives you two options:
  • try to open the one time boot menu at startup by pressing F12 or Esc (could be some other key, e.g. F9) and select something like legacy boot
  • open the BIOS settings with F2, Del (or some other key), navigate to startup resp. boot management and look for an option "enable legacy boot" or comparable there and activate it
If one of these steps work you know that it's an UEFI problem and your bootloader is still intact and working.
The other approach would be to check why UEFI now refuses to boot into Ubuntu even though it worked before. This can be caused by:
  • boot priority setting in the BIOS
  • GRUB fingerprint / signature has to be added to UEFI to be accepted as a legit boot loader
  • your GRUB is damaged and you could reinstall the bootloader from a Ubuntu Live CD
Here's the problem, from lines 1220-1221 in your Boot Repair log:
efibootmgr: Could not set variable Boot0002: No such file or directory
efibootmgr: Could not prepare boot variable: No such file or directory
Translated to English, the efibootmgr utility (a key part of installing an EFI boot loader from Linux) tried to create a new variable (Boot0002), but when it tried to set that variable as the default, it had disappeared from the firmware's memory. Basically, this indicates a bug in the firmware (or possibly in efibootmgr), or at least some sort of firmware glitch or misconfiguration. There are several possible solutions and workarounds, such as:
  • Upgrade your firmware (what the manufacturer probably calls a "BIOS") and try again. This may fix the bug.
  • Locate the firmware option to reset everything to factory defaults, use that option, then try again. This may clear cruft out of the firmware's data store, thus making things work more smoothly.
  • Register GRUB with the firmware in some other way, such as:
    • Using bcdedit in Windows, as described in my answer to this question.
    • Using the GUI EasyUEFI tool in Windows.
    • Using an EFI shell, as described in the Arch Linux wiki.
    • The point of all of these options is that it's possible that at least part of the problem is in efibootmgr, so using another tool may work better.
  • If the computer's new enough, return it to the store for a refund and buy one that isn't broken by design.
  • Use the "Advanced" Boot Repair option to back up and rename boot loaders. This will put GRUB in place of the Windows boot loader, thus hijacking the working Windows entry, and put a copy of the Windows boot loader elsewhere. This is an ugly hack of a workaround that's likely to come back and bite you later, since most tools won't know about the highly irregular state this workaround creates. Nonetheless, it may be the only solution in some extreme cases.
I'd try the solutions in roughly that order until one works, although you can try them in any order you like.
Rod Smith
  • 45,120
  • 66
  • 108
Had similar Problem: Win 7 and Xubuntu 15.10 -> Grub never started. When I tried to restore grub got similar message:
Could not set variable Boot000B: No such file or directory
So I used (under Windows as Admin) bcdedit /set {bootmgr} path \EFI\ubuntu\grubx64.efi as written above. Grub now working fine, but without Windows choosable.
Adding Windows to grub: I followed https://wiki.ubuntuusers.de/GRUB_2/Skripte/ (german) ->Create a executable skrip "29_windows" in "/etc/grub.d"
#!/bin/bash
# EFI-Partition suchen und auswerten
if [ -f /boot/efi/EFI/Microsoft/Boot/bootmgfw.efi ]; then
    EFI_UUID=$( grub-probe -t fs_uuid /boot/efi/EFI )
    echo "Menüeintrag für Windows eingefügt" >&2
cat <<EOF
menuentry "Windows 7 Pro (UEFI)" {
    insmod fat
    insmod chain
    search --no-floppy --fs-uuid --set=root ${EFI_UUID}
    chainloader /EFI/Microsoft/Boot/bootmgfw.efi
EOF
fi
and run
sudo grub-mkconfig
sudo update-grub
Grub found the Windows via script and automatically. Both are working so you may not need the extra script
